5 members (55shaker, Nick in Manitou, MickeyP, baldeagle, 1 invisible), 324 guests, and 2 robots.
Topics128,100
Posts1,056,178
Members48,436
#146795 05/10/2006 10:42 PM
Junior Member
Junior Member
Sorry for being a pain, but...I've been to the inliner's site and the info for this year isn't complete. But I think I see the 292 being my engine: 8921970
I entered the VIN from the door frame: C6336J137845, in the American Classic site and a 1 ton sub is what I get. Am I doing this wrong or is there something fishy here? I know this is at least a 1.5 ton, duals, with a dump bed.
Thanks again,
#146796 05/11/2006 12:01 AM
3B Offline
Hy WCKaner, The casting number for your engine I think is 3921970 which translates to a 63-76 292, I can't help with the truck serial number as Canadian serial numbers are different, hope that helps.
#146797 05/11/2006 1:22 AM
Junior Member
Junior Member
Thanks 3B it sure helps to know just what I'm working with.
#146798 05/11/2006 8:00 AM
X
X Offline
Your VIN decodes as a 1966 conventional cab 60 series cab & chassis with 157" wheelbase. That would be a nominal 2-ton with 19500# GVWR. There should be a GVW plate on the truck.
The 292 was the only inline originally available in the '66 60 series trucks. If you would like to further verify what the engine is, look for the serial number stamped on a pad just aft of the distributor.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
#146799 05/11/2006 4:43 PM
Junior Member
Junior Member
Guys, thanks so much for your help.
