1 members (TooMany2count),
119
Mod | | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 24 Junior Member | | Junior Member Joined: Apr 2006 Posts: 24 | Sorry for being a pain, but...I've been to the inliner's site and the info for this year isn't complete. But I think I see the 292 being my engine: 8921970 I entered the VIN from the door frame: C6336J137845, in the American Classic site and a 1 ton sub is what I get. Am I doing this wrong or is there something fishy here? I know this is at least a 1.5 ton, duals, with a dump bed. Thanks again, Bill | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy WCKaner, The casting number for your engine I think is 3921970 which translates to a 63-76 292, I can't help with the truck serial number as Canadian serial numbers are different, hope that helps. | | | | | Joined: Apr 2006 Posts: 24 Junior Member | | Junior Member Joined: Apr 2006 Posts: 24 | Thanks 3B it sure helps to know just what I'm working with. | | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | Your VIN decodes as a 1966 conventional cab 60 series cab & chassis with 157" wheelbase. That would be a nominal 2-ton with 19500# GVWR. There should be a GVW plate on the truck.
The 292 was the only inline originally available in the '66 60 series trucks. If you would like to further verify what the engine is, look for the serial number stamped on a pad just aft of the distributor.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
| | | | | Joined: Apr 2006 Posts: 24 Junior Member | | Junior Member Joined: Apr 2006 Posts: 24 | Guys, thanks so much for your help. Bill | | |
