4 members (carbking, CandoBrent, 2 invisible), 92 guests, and 3 robots.
Topics128,079
Posts1,056,286
Members48,441
#1466693 09/16/2022 3:44 PM
I took my gas tank out the other day. What are the pads behind it for and will it hurt to not use them. Also if they do need to be installed where do they go? The truck is a 1967 C10, tanks in the cab behind the seat.
The pads are anti-squeak pads, they prevent metal to metal contact, making the cab quieter.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks, what I thought but wasn’t sure. I’m assuming the go under the tank & behind the tank closer to the top of it. Mine fell and moved out of place when I removed the tank.
My pads did the same thing. Not sure if I will be reusing them or replacing with something a little more durable like rubber?
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
I used 1/8" thick peel and stick roofing material for the pads (Mule Hide)., I cut the 3' x 6' strip off the end that's sticky on both sides where the roofing overlaps.
It stuck to the tank and the straps so can't move. I used it on the cradle as well.
1950 Chevrolet 3100 (Ol' Roy)
I used Sound Control Mat from LMC Truck on my doors, floors, and behind gas tank. It’s a silver foil look but it’s not visible behind bench seat anyway. Also used insulation mat on floor and made panels covered in vinyl for doors.
1957 Chevy 3200
Daily Driver
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights.
Follow in the DITY
I used pieces of conveyor belt on my tank.
Brian
1955.2 3100 Truck
I bought some of this for radiator support rubbers. I was thinking the same thing for the fuel tank.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Moderator, Electrical Bay
For what it is worth, my experience has been the most important pads are the ones at the bottom of the tank. The AD cab moves in ways you might not expect and it will over time (granted a lot of time but still important) cause the tank to wear through and leak gas constantly. On mine, I got a piece of 1/8 inch pure neoprene rubber from a hardware store that had some and it will probably never wear through. A friend of mine said he folded common pvc shower pan liner over three times and used that.
~ Jon
blue67fleetside Used ordinary roofing tar paper,it is kind of lubricating and lasts well. Just folded it to fit,nice and quiet too.
I actually used pieces of an old inner tube. Easy to cut, easy to fit, and durable. Not to mention, free.
