4 members (wilbur53, klhansen, Steelonsteel, Bill Hanlon), 141 guests, and 2 robots.
Topics128,266
Posts1,058,368
Members48,485
#146764 05/08/2006 4:24 AM
I've got an early 60's axle from a 4000 series. Wanted to know year and ratio. Looked for codes on top of tubes like newer ones, and around front of gear case and flat spots on back by cover. Only thing I "dug" up was 114 in casting near pinion. Mean anything? I don't really want to remove cover to check, was just gonna advertise to sell. Usually end up cutting up and junking these big old things, never any luck selling. It has dual brake cyls, pretty good shoes yet. So where is ID? or is it not stamped on the outside?
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
#146765 05/08/2006 6:59 AM
X
X Offline
There should be a stamping somewhere on the carrier.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
#146766 05/10/2006 2:24 AM
3B Offline
Hy GLPerry, try looking at the end of the pinion there might be some numbers there, hope that helps.
