| | | Forums66 Topics128,266 Posts1,058,369 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | I've got an early 60's axle from a 4000 series. Wanted to know year and ratio. Looked for codes on top of tubes like newer ones, and around front of gear case and flat spots on back by cover. Only thing I "dug" up was 114 in casting near pinion. Mean anything? I don't really want to remove cover to check, was just gonna advertise to sell. Usually end up cutting up and junking these big old things, never any luck selling. It has dual brake cyls, pretty good shoes yet. So where is ID? or is it not stamped on the outside?
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | There should be a stamping somewhere on the carrier.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
| | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy GLPerry, try looking at the end of the pinion there might be some numbers there, hope that helps. | | |
