Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (baldeagle, 66flea, GMCJammer51, ndkid275), 39 guests, and 3 robots.
Topics128,004
Posts1,055,246
Members48,418
#146750 05/08/2006 12:09 AM
Can someone point me to a source for rear spring shackles for a '48 Chevy 1 1/2 ton?
#146751 05/08/2006 3:27 AM
I
I Offline
Whats wrong with the ones on it? Ussally the bushing are shot. If the casting is worn you can drill them out and put a sleeve in them then the final bushing. Jim Carter has most of the stuff you need to repair the springs.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
#146752 05/08/2006 4:09 AM
Go to your local spring shop/wholesaler. One here in Ft. Wayne, IN has those in stock or 2 days to order if not. Much cheaper than mail order places too. Usually just the pins get worn, and you will probly need the wedge pins that hold them new, I usually brake mine or beat them up taking them out. For shackles themselves, you may have to find used. Try Bow Tie Bits for used big truck parts.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
#146753 05/08/2006 9:40 AM
I found some NOS on ebay when I needed some for mine. Call around and try to find some if you like. You may try Bruce at 804-752-6036, he is in VA, call at a reasonable time of day. He has had many of the NOS parts I have needed.
But if there is nothing wrong with the casting / forging just replace the pins and bushings and lock pins. That's normal spring shop stuff, not hard to find.
1952 Chevrolet 3800 pickup
---All pictures---
