| | | Forums66 Topics128,089 Posts1,056,352 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | I have searched several post here related to Epoxy Primer and see a lot of different methods. I am stripping a bumper to bare metal in vinegar ( I have used vinegar on other parts with great success). I plan to spray with Eastwood Epoxy primer.
2 questions. I have seen a post that states Epoxy primer needs to be "force dried" by heat lamps or in a booth. Is this true for the Eastwood Epoxy Primer out of the spray can? I have also seen different suggestions for what to spray on over the Epoxy primer. What is the best next coat (sandable primer?) and what is the window? Do I spray within the recoat window or wait.
NOTE: I will be using rattle cans, not a spray gun.
| | | | | Joined: Mar 2010 Posts: 58 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 58 | Epoxy primers don't need to be force dried. After 24 hours, they need to be scuffed up before recoating. The next step would be a sandable filler primer, then you can paint over that. | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Also best to select your topcoat and see what is compatable with that.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Mar 2010 Posts: 10,286 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,286 | Rattle can epoxy primer? I thought that epoxy primer was a two part product. Does the rattle can have two compartments inside?
| | | | | Joined: May 2015 Posts: 11,084 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,084 | I’ve used rattle can epoxy a couple times. There’s a breakable capsule inside that you break with a plunger. Spraymax is the brand I’ve used.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | Yes. The rattle can has a plunger on the bottom. It has a 24 hours pot life once you activate it. I am using Eastwood. Can I spray the Sandable primer directly over the epoxy without scuffing it if I do it within the recoat window? Eastwood 2-Component Epoxy Aerosal Spray - black or gray
