3 members (Bill Hanlon, joe apple, Gdads51), 93 guests, and 4 robots.
Topics128,088
Posts1,056,372
Members48,442
I have searched several post here related to Epoxy Primer and see a lot of different methods. I am stripping a bumper to bare metal in vinegar ( I have used vinegar on other parts with great success). I plan to spray with Eastwood Epoxy primer.
2 questions.
I have seen a post that states Epoxy primer needs to be "force dried" by heat lamps or in a booth. Is this true for the Eastwood Epoxy Primer out of the spray can?
I have also seen different suggestions for what to spray on over the Epoxy primer. What is the best next coat (sandable primer?) and what is the window? Do I spray within the recoat window or wait.
NOTE: I will be using rattle cans, not a spray gun.
Dave from Northern Kentucky
My 54 3100
Epoxy primers don't need to be force dried. After 24 hours, they need to be scuffed up before recoating. The next step would be a sandable filler primer, then you can paint over that.
'66 C60 body, '97 C6500 chassis, '07 LBZ Duramax with Allison 1000
https://photos.app.goo.gl/cxwv1C6Ay2oxYH7u7
Also best to select your topcoat and see what is compatable with that.
Dennis
40 Chevy 1/2 ton
Rattle can epoxy primer? I thought that epoxy primer was a two part product. Does the rattle can have two compartments inside?
I’ve used rattle can epoxy a couple times. There’s a breakable capsule inside that you break with a plunger. Spraymax is the brand I’ve used.
Yes. The rattle can has a plunger on the bottom. It has a 24 hours pot life once you activate it. I am using Eastwood. Can I spray the Sandable primer directly over the epoxy without scuffing it if I do it within the recoat window?
Eastwood 2-Component Epoxy Aerosal Spray - black or gray
My 54 3100
