3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#146717 05/06/2006 8:19 PM
Junior Member
Junior Member
I just bought my first, in a long time, old chevy truck. It's a 66 C60,dump (I think)I haven't gotten it home yet. A buddy heard about my new truck and offered me a fresh rebuilt 283 out of a 60's? Owens cabin cruiser, single screw. A trade, of yet to be determined value, if this can be of good use.
Thanks for this great site and your help!
#146718 05/06/2006 8:35 PM
3B Offline
Hy WCKaner, welcome, yes the 283 is the same basic engine as used in vehicles, you might have to change the oil pan, and possibly the oil pump pickup, but other than that everything should be copasetic. Hope that helps.
#146719 05/06/2006 10:17 PM
make sure it is the correct rotation. Often when two engines are used in one boat they turn opposite dirrections. It may only need a new cam, distributor, oil pump, and starter to change dirrections if you need to.
1952 Chevrolet 3800 pickup
---All pictures---
#146720 05/07/2006 3:35 AM
If it has the wrong rotation, the offset on the wristpins will be wrong. GM used an offset on the piston wristpin on a some of their engines to counteract piston slap.
1951 1 Ton Completed
#146721 05/07/2006 3:53 AM
He said the boat had a single screw. For you landlubbers, that means there is only one prop, i.e., only one engine. Therefore it is highly doubtful it is a reverse rotation engine.
#146722 05/07/2006 4:59 AM
So what if it is reverse rotation, this is a dump truck, they go backwards as much as forward anyway don't they!
#146723 05/07/2006 12:00 PM
Take a quick look at the oil dipstick location. On a lot of the marine engines, we drilled the boss specified by the boatbuilder. Auto application had the dipstick on the driver's side.
#146724 05/07/2006 11:57 PM
We used to have a houseboat with twin 283 engines.
The alternator, heads, waterpump, distributor were marine usage only.
The waterpump drew lake water threw the heads which cooled the engine. The exhaust manifolds were different also.
In my experience, it is not worth the cost to convert a marine engine to a radiator engine and vice versa.
Jim
Here is a link to some stuff about my brothers and I
http://bus-plunge.blogspot.com/search?q=hemmings
#146725 05/08/2006 2:09 AM
Junior Member
Junior Member
Thanks everyone for your advise. I hope the 6cyl in the truck will be in good shape. I won't have to replace it.
