7 members (Otto Skorzeny, klhansen, Hotrod Lincoln, 3800GUY, farmallb, Rustnut, 1 invisible), 70 guests, and 4 robots.
Topics128,079
Posts1,056,301
Members48,441
'40 Chevy 1/2t School Shop Project
On my 1940 Pickup, My speedometer needle is broken and I'm not sure on the other gauges functionality. The truck is converted to 12v as well. What options do I have for fixing it or what have others done to get there instrument cluster functioning again? I tried searching but didn't see anything for a '40.
High School Shop Project
1940 Chevy 1/2-ton
In the Project Journal
I was lucky when I bought my 40 project, it came with several extra gauge clusters, so I was able to come up with good working gauges. But it's pretty easy to check and test your gauges. The amp gauge doesn't care if it's 12 volt or 6 volt. It just measures current. If you measure across it with an ohm meter, it should measure close to zero ohms. If not, then it has a problem. If yes, it doesn't necessarily mean it's good, but it indicates that it probably is. You'll have to feed a larger amount of current through it to be sure. The gas gauge DOES care about 12 volts. You'll need to buy a voltage reducer for it, unless you can find a dealer who offers a 12 volt version. I've found that the active reducers sold by the dealers work fine. I can't remember if you need a different sending unit for 12 volts or not, but I think it probably does. The temp gauge, and oil pressure gauge are strictly mechanical and don't care about 6 volt or 12 volt. You can put the bulb at the end of the temp gauge tube in water that is boiling or near boiling to see if it works. Connect the oil pressure tubing up to a running engine to see if it registers. On the 1940 trucks, all of the graphics are printed on the inside of the large rectangular glass. I tried to wash mine, and it washed the printing off, so I had to buy a new printed glass. You can send the chrome outer trim off to be re-chromed. I painted the background of the cluster with old fashioned ruddy red primer. It isn't an exact match, but is in the ballpark, and it looks good with the other interior colors.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
Im sure that any speedo shop can replace your broken speedo needle. Or, you can probably do it yourself, if you can find one. Speedo's are often stuck from many years of sitting. I've had success with a tiny bit of light oil, letting it sit, and then very slowly trying to work it back and forth. I've found that they free up pretty easily, and work well afterward. Hopefully you'll also hear from some of the guys on here that are more knowledgeable than I am.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1947 Indian Chief
1943 Indian 741
Same sending unit will work assuming you have a good voltage reduction unit for the gauge.
Check out "Bowtie Bits". I got my gauges from them.
Another quality post.
Real Trucks Rattle
Thanks for the help! Good type on the glass, glad I didn't wash off the inside!
1940 Chevy 1/2-ton
