0 members (),
130
Mod | | | Forums66 Topics128,077 Posts1,056,034 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | I'm wondering if anyone has any knowledge on a 1953 half ton frame compared to a 1954 half ton frame.
My 53 frame has a bad spot where the front of the right rear shackle mounts, and I am looking (across the state) at a 1954 half ton frame to take it's place. I see that the very back cross member is a little different looking, but are there other differences that would make it not work?
Thanks!! | | | | | Joined: May 2015 Posts: 11,063 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,063 | As far as I know, the only real significant difference is the rear frame humps and crossmember being lower. That was to fit the deeper bed (lower floor). You should be able to bolt a 47-53 bed on a 54 frame without issues.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2000 Posts: 2,192 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,192 |
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | |
