5 members (J Lucas, Brian Moore, Pete1946, Otto Skorzeny, Hotrod Lincoln), 124 guests, and 3 robots.
Topics128,072
Posts1,055,903
Members48,429
#1466968 09/17/2022 9:32 PM
I'm wondering if anyone has any knowledge on a 1953 half ton frame compared to a 1954 half ton frame.
My 53 frame has a bad spot where the front of the right rear shackle mounts, and I am looking (across the state) at a 1954 half ton frame to take it's place. I see that the very back cross member is a little different looking, but are there other differences that would make it not work?
Thanks!!
As far as I know, the only real significant difference is the rear frame humps and crossmember being lower. That was to fit the deeper bed (lower floor). You should be able to bolt a 47-53 bed on a 54 frame without issues.
Insomniac
Insomniac
I believe that the cross member where the rear engine mounts is different.
http://www.1954advance-design.com/Documents/EngineeringFeatures/slides/orig_Page49.html
Gord 🇨🇦
1954 1/2 ton 235 4 speed
