1 members (Cosmo), 69 guests, and 0 robots.
Topics128,035
Posts1,055,564
#1466785 09/16/2022 11:28 PM
'40 Chevy 1/2t School Shop Project
Hello, I'm digging into the 1940 1/2 ton. I've managed to find out it came out of the Baltimore plant in 1940, and from what I can tell it never got further then a 60-100 mile radius of where it was made! She still has both her original MD license plates from '40 as well. I'm trying to see if the Engine is correct. Block says GM with a 20 underneath, and then casting # of 3769716.
High School Shop Project
1940 Chevy 1/2-ton
In the Project Journal
That's pretty cool that you have the original plates. Does Pennsylvania allow you to register vintage plates and put them on the truck?
1950 Chevrolet 3100 (Ol' Roy)
Chevrolet 3769716
Category Engine Blocks
Type Inline-6
Date 1958-1962
Notes 235 CID, Chevrolet
Unfortunately for originality, it doesn't look like the engine is original. The 3769716 casting number, according to this is a '60 or '61 235 ci truck engine. But that's a good engine for a driver.
Thanks guys for the info!
1940 Chevy 1/2-ton
Crusing in the Passing Lane
Pictures would be nice!
Ed
Second!
He has a lot of photos in his “Project Journal” thread.
So on the flat boss behind the dip stick it has FO22IJC. Does that helps date it better?
Here's some engine pics, Also I need help ID'ing the carb. so I can get the correct Rebuild kit, it's a Rochester.
1940 Chevy 1/2-ton
F0221JC breaks down as follows.
F = Flint Engine Plant
02 = Month (Feb)
21 = Day
JC = 235 engine used in a 4000 series truck from 1958-62.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks everyone!
1940 Chevy 1/2-ton
