0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 44 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 44 | Quick question Does a 1/2 ton and 3/4 ton use the same brake shoes I have 2 adjustment holes on the backing plate
| | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | No 3/4 ton is different everything from the 1/2 ton Maybe they share the same lug nut. -s | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | No. The 3/4 ton has larger brakes then the 1/2 ton. You don't say what year it is but the 73 on back 3/4 ton had Huck brakes. Yours evidently has huck brakes as it has 2 adjustment slots that probably are in the top portion of the backing plate.
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2009 Posts: 5,844 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,844 | plane_fixer, IIRC, they are not the same. More detail needed as not sure if this question applies to "Thelma" or another truck.  Pretty sure on 51-55 1st Series 1/2 ton fronts and rears where different from each other, and 3/4 - 1 ton were different from 1/2 ton altogether. Seems to me 3/4 - 1 ton used same shoes sets front and rear. Try doing a search by vehicle info on NAPA website. You may find what your are looking, or a lead towards another supplier.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | 3/4 and 1 ton don’t share completely I think some years used the 1 ton front shoes as the 3/4 rear shoes but my memory is hazy The 1 ton rear is a 14 inch brake drum, larger than anything on a 3/4
But I assumed we were discussing 1950s trucks So maybe later years they start to share more -s | | | | | Joined: Oct 2010 Posts: 44 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 44 | Thanks guys It's a 49 3600 (Thelma on my profile is a 1950 3600) when I did a quick search on Google the ones that came up just said 1949 Chevy pickup
| | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Finding Huck brakes for 3600's and 3800's can be a bit tricky. John had to have the brake shoes relined on his 3800 pickup, and the first try didn't take- - - -the bonding glue on the linings failed and the linings came off the shoes. I think the rebuilder ended up doing some riveting on the second attempt. If the shoes aren't worn or damaged, don't discard them. They can have the friction material replaced. Jerry
| | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 | Contact this company. Scott & Margaret Bethke Brake Materials & Parts Inc 800 Sherman Blvd Fort Wayne IN 46808 Phone: 260-426-3331 Fax: 260-424-1331 Email: [email protected]Website: http://www.BrakeMaterialsAndParts.webs.comFacebook: www.facebook.com/BrakeMaterialsAndParts
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Oct 2010 Posts: 44 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 44 | Thanks Jerry and otto
