4 members (artinva, Shaffer's1950, Chip O, Rich'sToys), 113 guests, and 2 robots.
Topics128,072
Posts1,055,903
Members48,429
#1466679 09/16/2022 2:27 PM
Quick question
Does a 1/2 ton and 3/4 ton use the same brake shoes I have 2 adjustment holes on the backing plate
plane_fixer #1466683 09/16/2022 2:49 PM
2 Offline
No
3/4 ton is different everything from the 1/2 ton
Maybe they share the same lug nut.
-s
plane_fixer #1466684 09/16/2022 2:51 PM
Riding in the Passing Lane
No. The 3/4 ton has larger brakes then the 1/2 ton. You don't say what year it is but the 73 on back 3/4 ton had Huck brakes. Yours evidently has huck brakes as it has 2 adjustment slots that probably are in the top portion of the backing plate.
George
1972 Chevy c10 Cheyenne Super
plane_fixer #1466688 09/16/2022 2:56 PM
plane_fixer,
IIRC, they are not the same. More detail needed as not sure if this question applies to "Thelma" or another truck. headscratch
Pretty sure on 51-55 1st Series 1/2 ton fronts and rears where different from each other, and 3/4 - 1 ton were different from 1/2 ton altogether. Seems to me 3/4 - 1 ton used same shoes sets front and rear.
Try doing a search by vehicle info on NAPA website. You may find what your are looking, or a lead towards another supplier. thumbs_up
~ Dan
1951 Chevy 3 window 3100
plane_fixer #1466692 09/16/2022 3:22 PM
2 Offline
3/4 and 1 ton don’t share completely
I think some years used the 1 ton front shoes as the 3/4 rear shoes but my memory is hazy
The 1 ton rear is a 14 inch brake drum, larger than anything on a 3/4
But I assumed we were discussing 1950s trucks
So maybe later years they start to share more
-s
plane_fixer #1466699 09/16/2022 4:21 PM
Thanks guys
It's a 49 3600 (Thelma on my profile is a 1950 3600) when I did a quick search on Google the ones that came up just said 1949 Chevy pickup
plane_fixer #1466738 09/16/2022 7:31 PM
Finding Huck brakes for 3600's and 3800's can be a bit tricky. John had to have the brake shoes relined on his 3800 pickup, and the first try didn't take- - - -the bonding glue on the linings failed and the linings came off the shoes. I think the rebuilder ended up doing some riveting on the second attempt. If the shoes aren't worn or damaged, don't discard them. They can have the friction material replaced.
plane_fixer #1466739 09/16/2022 7:33 PM
Contact this company.
Scott & Margaret Bethke
Brake Materials & Parts Inc
800 Sherman Blvd
Fort Wayne IN 46808
Phone: 260-426-3331
Fax: 260-424-1331
Email: [email protected]
Website: http://www.BrakeMaterialsAndParts.webs.com
Facebook: www.facebook.com/BrakeMaterialsAndParts
1950 Chevrolet 3100 (Ol' Roy)
Thanks Jerry and otto
