| | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2015 Posts: 96 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 96 | For my 52 GMC burb. Was looking for info on converting my sliding windows to one piece glass and found an old thread that had this, https://www.classicparts.com/1947-5...ip-Kit/productinfo/01-505/#.UljaHj3n_IU. Looks to be good/current at Classic Parts. Anyone used this kit? I don't have glass or any of channels, felt strips, etc. I do have the SS pull bars and inner and outer trims. Anything else needed? Don't have anything to look at to compare or to tell me just what was in there originally. Had consigned myself to solid glass but might now consider going sliders. Any thoughts or help appreciated. Can see the light at the end of the tunnel! Shooting for December completion. I can dream can't I? AZCornman | | | | | Joined: Oct 2005 Posts: 4,251 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,251 | | | | | | Joined: Sep 2015 Posts: 96 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 96 | Thanks for the reply Mark. I've looked at that install post of yours several times. I'm now understanding it a little better. Like I posted, I have the bare window, SS slider with the tab on it, and all the trims inner and outer and the inner trim mounting strips. I'm not quite sure about the "channel". Is it a metal that has to be formed to the frame per your instructions? I've seen other posts that created channel with aluminum U channel. Is that not needed with this kit? ie Is the kit all thats needed? Also, does the forward stationary channel just friction fit between the trims? Or glue it in? I know I'm sounding a little "dense". Sorry, just want to understand clearly. I've bought the glass patterns from Jim Carter. I've found a 52 gmc just like mine in the weeds up the mountain (army ambulance) that I'm going to check out to get a better understanding.
Thanks again,
Rick | | | | | Joined: Oct 2005 Posts: 4,251 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,251 | It's been such a long time, I'll need a minute or two to review what I dd back then. So, give me a minute. I'm also going to need to do the job again as it is time to strip it down for paint. So, this time around, I'll take better pictures and see if the tech tip needs updating.
BTW, the channel is the same type of felt channel stuff used for the windows in the passenger doors. It's held in by a combination friction, glue and screws if I remember. Everything you need is in the kit. Except for the weather strip adhesive. | | | | | Joined: Sep 2015 Posts: 96 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 96 | OK, thanks. Looks like I'll give it a try. I'll watch for any update you might post.
Rick | | | | | Joined: Sep 2015 Posts: 96 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 96 | So I've been investigating this issue a couple of months now. Classic parts still show the window slider kits...but they are on backorder. Sales lady says that their distributor is lacking parts that are backordered.... from overseas. Supply chain?? Jim Carter has a kit listed, part # WI-207, but the picture only shows the glass run channel. The salesman is having trouble understanding the parts I'm explaining to him. Maybe a new guy? Anyway, does anyone know or have any experience with the Carter glass slider kit?
Richard | | |
