Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
0 members (), 557 guests, and 1 robot.
Topics126,777
Posts1,039,270
Members48,100
Most Online2,175
Jul 21st, 2025
#1466299 09/13/2022 9:41 PM
Hey everyone! so, I was not planning on making another post however we had someone come over and showed us where the engine cast code was (Under a lot of paint and dirt) The first half of it is fully missing, but the second half is V0330TND if anyone knows what (mainly that TND part) means, I would love to find out!
Can you post a picture of your engine code...that might help.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1956 8400 Wrecker w/Holmes 525
1956 9200 Tractor w/Allison Automatic
1952 Willys M38 Army Jeep
1953 Willys M38A1 Fire Jeep
1978 Jeep CJ-5 Navy Jeep
1984 Jeep CJ7
Hughesville, MD
Hopefully that helps! Though its not much more than i already said
GMCDumpTruck72,
Your stamped code "V0330TND" is the full "engine ID code".
Did a little web searching and found this resource:
https://media.lmctruck.com/Catalog_Chassis-Eng_IDs/Engine_ID/CD_Engine_ID.pdf (all credit to lmctruck for making this available) thumbs_up
V= Flint MI plant
03= March
30= 30th day
TND = '92 350 originally installed in 2wd/4wd 1/2 and 3/4 ton trucks
You can further confirm by finding block and head casting numbers and checking the web if you need to.
~ Dan
1951 Chevy 3 window 3100
Originally Posted by Gdads51
GMCDumpTruck72,
V= Flint MI plant
03= March
30= 30th day
Thanks for the info! This might be me beinf dumb but wouldnt that engine have more modern features? Our still has a manual fuel pump, no sensors other than the temperature sensor, v belts things like that. Just curious thanks again!
You are correct, would probably "originally" have had all the '92 era gobble-de-gook - before it got transplanted.
A snippet from another source that I found had this info: TND= '92 truck, 350, 210hp, manual tranny, TBI, 10 and 20 series C/K L-05 RPO code
(TBI being throttle body injection)
All that stuff most likely removed and discarded. Basically a 350 long-block transplanted into your '72, with '72 era fuel pump, etc. installed to replace the newer stuff removed.
Hope this helps answer your question???
~ Dan
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.245s Queries: 15 (0.062s) Memory: 0.6157 MB (Peak: 0.6983 MB) Data Comp: Zlib Server Time: 2025-09-22 07:26:54 UTC
Valid HTML 5 and Valid CSS
