6 members (greenie-reddy, FAST55, MRMEROTH11, Otto Skorzeny, 1955 1 Series, Hotrod Lincoln), 107 guests, and 1 robot.
Topics128,051
Posts1,055,768
#1465396 09/06/2022 4:34 PM
How many miles can you get out of an oil change when running a bypass oil filter on a 235 engine, 3000 miles?
Brian
1955.2 3100 Truck
O Online: Content
It will probably be good for a lot more than that but who cares?
I change the oil in every single vehicle I've ever owned at 3000 miles regardless of whether or not the oil or filter might last longer.
$30 or whatever an oil change costs is very cheap insurance.
1950 Chevrolet 3100 (Ol' Roy)
I change oil/filter in the Fall and Spring which is probably more often than necessary.
Cold weather + short trips: small interval
Warm + long trips: long interval
H Online: Content
Run a Frantz filter, change it once a year, and top off to the full mark on the dipstick whatever oil is lost during the filter change. The 855 Cummins engines we ran that way had 50K miles or more without a full oil change. Oil analysis by an independent testing lab after every filter change confirmed that the oil was still within limits for continued use.
Is that with TP or a Frantz cartridge?
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
H Online: Content
My supplier custom wound bulk TP into a cartridge that fit a LuberFiner 750 canister. It was about 6" in diameter and a foot long. IIRC, we changed filter elements on a 6 month rotation, about 30K to 50K miles. It took about a 1-gallon fresh oil top off with new oil in a 10 gallon capacity system.
7
7 Offline
I put my Detroit Deisel's in for service at 30,000 miles, that was in the eighties with 8V-71's and 6V-92's. Loaded at 50,000 lbs. one way and 80,000 lbs. heading home. Of course they ate 2 quarts each trip so it was like a small oil change each night.
55shaker My 235 came to me with a bearing noise that oil pressure would shut it up. Put in -.002 rod bearings in the truck,old ones dark not out. I knew this wasn't the trouble,gasket stayed on the block,put the pan back on ran a few months. -.002 mains appeared for 40$$ pulled the pan rolled in -.002's fixed it !! Now keeps 30 lb. gauge pegged summer and winter. Itmostly changes it's own oil from leaks and use,straight propane burner doesn't suffer with sludge,oil stays like new about 11'000 miles by now is fine.
