3 members (TUTS 59, klhansen, cmayna), 76 guests, and 3 robots.
Topics128,099
Posts1,056,501
Members48,444
C Online: Content
Was reading Mike Burns thread on the gas pedal rod and went out to my truck to view my setup and discovered that either I or someone, a long time ago shortened the length. So my question is when installing a '63 235 into a 49-54 truck does the stock 216 accelerator rod need to be shortened because the 235 is longer than a 216? My 235 came out of my '53, which I'm sure originally had a 216 way before I bought it. So I assume this modified pedal rod was already shortened during it's life in the '53. Then when my Front oak tree came down and crushed the '53, I bought the '50 and transferred the entire drivetrain from the '53 to the '50.
Below is a pic of my pedal rod which was shortened.
Craig
Craig
My blog post explains the problem. Some choose to shorten the rod rather then move the pivot point.
http://chev235guy.blogspot.com/search/label/216%20235%20Throttle%20Pivot%20Positions?m=0
My Blog
2 Offline
When you list two numbers like
9 1/8 and 12 9/16 in the same line
What do they mean, which is it?
Like one of them is probably a dimension from the back of the block but if so then what is the other dimension
It’s important to be explicit in documentation and instructions
Ambiguity leads to questions like I have now
-s
C Online: Content
Dave,
Thanks a bunch on the info. It all makes sense. Went out and looked for a forward pivot position and nope, not there. It's worked flawlessly for so many years. To self: Don't touch
Craig
-s
This chart was made for me as a reference in my shop to help me when I needed to modify an engine for conversion.
I see where someone coming in without point of reference could be confused.
When I get a minute I will rewrite my blog post to clear it up.
My Blog
