2 members (texas46, Otto Skorzeny), 152 guests, and 4 robots.
Topics128,101
Posts1,056,180
Members48,436
#1464710 08/31/2022 6:05 PM
I can't seem to get the pitman arm off. I quit using my puller because I was afraid it was going to break. I borrowed a beefier one from OReilys that I broke this morning.
I tried whacking it with a hammer with tension on the joint.
I didn't try heat for fear of ruining the seals.
I'm stymied.
Will the box come out with the arm attached?
How much stuff has to be removed underhood to make room to maneuver it out?
Thanks.
Leon
I don't think you'd ruin the seal as long as you don't apply heat to the sector shaft. Just heat the pitman arm a bit and it should come off. Heat with some tension applied to the puller should do the trick.
And if you're pulling the steering gear, you'll probably want to replace the sector seal with a modern lip seal anyway instead of eh original felt seal.
Try using a 4# hammer as a backup on one side of the arm at the splines a hit the opposite side with a 2# hammer. Just as you think you can't make another swing it will pop loose. Leave nut on loosely to protect threads.
Yes the column will drop out the bottom IF you have a way to raise the front of the truck about three feet or have a lift to raise the whole truck.
We use an air chisel/hammer with an available smoothing hammer attachment that we ground a concave end on it to stay centered on the pitman arm eye. Pops them loose in seconds.
Evan
Thanks, Kevin
I decided to give heat a try based on your suggestion.
I pulled out my torch and discovered that the hoses were dry rotted and both bottles were empty.
<Sigh>
Some days you should just stay in bed.
So I'm off to Tractor Supply.
Try again tomorrow.
regards,
Leon
Care with any method involving a hammer, the sector gears will not respond well to shock force, soak the pitman x sector joint with penetrant…a lot….
More inclined to heat/cool (torch & ice) to break the seized connection, heat the sector as possible then ice cold rag the pitman.
Mine came free relatively well, lucky I guess….
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
Yep. I've used that method quite a few times. It makes the rust molecules let go and cover their ears. grin
Works really well with tapered tie-rod ends. Better than a pickle fork that screws up the rubber cover. A little pressure on the end of the shaft (with the nut on) and they pop loose.
I can't really use a hammer very well because the pitman arm eye is shrouded by the box.
I still haven't had a chance to try heat.
I got a new set of hoses and refilled the bottles last night. Got it all set up and discovered that my #1 tip has gone walkabout. I've got a #00 and a #4 cutting tip. The pitman arm would jist giggle at the size flame out of a #00.
I checked with the local hardware store, Tractor Supply, Atwoods, Harbor Freight, and Lowes/Depot. They all only have cutting tips and rosebuds. The local welding store wants $65 for a #1 welding tip.
After the rain slacks off, I'm going to go try with the cutting tip. It should be fine -- just a little unwieldy for the cutting torch under the fender.
Leon
Heat is heat. You can use the #4 as long as you don't leave it in the same spot for too long. You don't need to get the eye red hot (and shouldn't.)
No joy. I heated the eye short of red and whacked it with a hammer as best I could while under tension from my puller.
Evan (coilover), did you mean the box & column could come out the bottom with the pitman arm still on it?
Leon
I got it out. I loosened the inner fender and pried it outboard for clearance, per the shop manual.
Then, with a lot of wiggling, it came out the top with the pitman arm still attached.
If I'd only known beforehand, I could have saved several hours messing with the pitman arm.
Maybe the next guy will find this thread and benefit from it.
regards,
Leon
Leon,
Glad you were able to win the battle. yahoo
Thanks for the follow-up notes as those definitely help others when searching for help/answers! thumbs_up
On a side note: Are we maybe neighbors??? (I've been in Grandview since late 1994.)
Dan wave
~ Dan
1951 Chevy 3 window 3100
