6 members (dt235sd, Opelika Tom, Gdads51, HandyAndy, 78buckshot, 1 invisible), 105 guests, and 4 robots.
Topics128,062
Posts1,055,847
Members48,428
#146438 04/10/2006 7:02 PM
On my 54 6400 the lug nuts are off but the wheel won't budge. Any tricks on getting the wheel off? I don't want to beat on it too much for fear of bending the rim.
Matt
"Brunhilde II" '59 Viking 60
To paraphrase Ben Franklin: "Big Bolts are proof that God loves us and wants us to be happy"
#146439 04/10/2006 8:04 PM
I
I Offline
Your rim is like most, stuck on the hub in the center. Spray this area with a lot of PB Blaster and I use a portapower to push them off. Dont think you'll get them off buy beating on them.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
#146440 04/10/2006 10:37 PM
Junior Member
Junior Member
hey matthew try taking a strap and looping it through the rim. take the other end and put it on the hitch of a truck.be very carefull when you tug on it that you dont pull the truck off the stand, the truck prob wont move because it quite heavy, good luck.
Trey Deluna
#146441 04/11/2006 12:38 AM
Matt, don't use a strap, bad things can happen if you do that. hit the rim in between the studs to loosen the bond between the rim, drum and studs. soak the studs with some sort of WD40 or the like and try to get it behind the rim. those are thick steel wheels...you're not going to hurt it by hitting it with a small sledge hammer, just hit it square and solid. It will come off...trust me. I have three of those trucks myself.
I do like Iowa 59's answere also. the strap idea will force the wheel to come off but also may jam it into the studs if it comes off crooked...you don't want that to happen.
'41 Chevy G7107
'42 International M-3L-4
'44 stude US6
'50 GMC 250
'53 Chevy 6400
God bless our military, radical dictators and the ignorant people who follow them for enabling the USA to build these fine machines.
Travis Weedman
#146442 04/11/2006 2:03 AM
another method is to put the lug nuts back on and leave them a little loose then take the truck down the road starting and braking at low speeds the weight of the truck starting and stopping will break it loose you run the risk of boogering the threads if you leave them too loose
#146443 04/13/2006 12:53 AM
thanks for the tips
Matt
#146444 04/15/2006 2:34 AM
To save possible damage to the rim, use a piece of 2 X 4 or other wood between the rim and a big hammer. It will spread the blow over a larger area and not ding up the metal. You can beat the stuffing out of the wood before you hurt the rim but the energy will be passed through.
#146445 04/16/2006 2:09 AM
Big hammer and hit on TIRE, and it will bounce off, yet create a vibe or counter action. I've had this work many times. Turn tire to new spots as you go. Also, you can clean the area where rim hole meets the hub with a sharp pointed item or knife. There is a tiny space there, rusted up. Lots of PB Blaster spray, and around lugs too.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
#146446 08/18/2006 5:20 AM
I used Grumpy's method and it worked for me.
