1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2022 Posts: 162 'Bolter | | 'Bolter Joined: Feb 2022 Posts: 162 | 53, 3100 installing a new wiring harness, harness has wires for turn signals , but truck didn't come with any turn signal switches. What do you all use.
1953 with a 216
| | | | | Joined: Jul 2000 Posts: 2,189 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,189 |
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Aug 2003 Posts: 108 'Bolter | | 'Bolter Joined: Aug 2003 Posts: 108 | Check ebay for "turn signal switch"-- throw in "vintage" for old ones. I have a vintage Signal Stat 400 in my '53 3/4 ton, and a Yankee (700?) in my '47 Hudson. You can get a nice new one for under $30; I just picked up one of these for the '46 Chevy Aerosedan I'm building:
https://www.ebay.com/itm/334344925599?hash=item4dd882b19f:g:6qMAAOSwTcxggO~E
So, there is a ton of options regarding switching. Some of the switches are 4 wire (2 wires from flasher in, 2 wires out to left & right side signals), and some are 7 wire (2 in from flasher, 1 to stop/brake switch, and one to each light). If you find a vintage switch you can just google up the wiring diagram for it based on model number; if you buy a new one it should come with wiring instructions. Most guys will put the front signals into the parking lamps mounted on the grille (what I did on my '53 3600); as for the rear signals it will partly depend on what kind of switch you get. 4-wire switches require an extra bulb in the rear lamps, whereas 7-wire switches will have the existing brake lights double as the signals. | | |
