1 members (UtahYork),
215
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2022 Posts: 100 'Bolter | | 'Bolter Joined: Aug 2022 Posts: 100 | I am a new '46 owner and I’m trying to remove the front seat to access the gas tank. I can’t seem to figure out how to remove the seat bottom. I “thought” you simply pulled up to remove the bottom / base of the seat, but mine is not budging. Before I apply excess force and possibly break or bend something, I wanted to make sure this was correct. Simply, how do I remove an original seat from a 46 AK?
Care taker of a 1946 1/2 ton. Pretty much period correct original. Danny T, from B’ham, Al
| | | | | Joined: Aug 2022 Posts: 100 'Bolter | | 'Bolter Joined: Aug 2022 Posts: 100 | Hey guys, no one knows how to remove the seat bottom? I really would appreciate the help, if anyone knows.
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | The back has a couple of curved tabs that fit into slotted brackets on the rear edge of the seat portion. Try lifting up on the back while pulling up on front edge of seat. Underside of seat frame has a few holes ( allows adjustment ) Metal frame around gas tank supports 4 brackets with raised pins to position seat. A bit tricky with one person - best with 2 | | | | | Joined: Apr 2004 Posts: 5,074 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,074 | There are two Tech Tips regarding seats that *may* help some: Easier seat adjustmentSeat RestorationThey may have some pointers that will help. They definitely have pictures! Welcome to the site, BTW.
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Aug 2022 Posts: 100 'Bolter | | 'Bolter Joined: Aug 2022 Posts: 100 | Thank you Britcon and Peggy M.
This information was very helpful, although I still can’t get the seat to come lose. It’s obviously connected at the back, where the seat bottom joins the back, as you guys had said. But I still can’t get it to come lose. I’ll try again later
