4 members (Woodcmiami, Bill Hanlon, Gray_Ghost, J Lucas), 114 guests, and 2 robots.
Topics128,108
Posts1,056,238
Members48,437
#1463983 08/26/2022 6:46 AM
I am a new '46 owner and I’m trying to remove the front seat to access the gas tank. I can’t seem to figure out how to remove the seat bottom. I “thought” you simply pulled up to remove the bottom / base of the seat, but mine is not budging. Before I apply excess force and possibly break or bend something, I wanted to make sure this was correct. Simply, how do I remove an original seat from a 46 AK?
Care taker of a 1946 1/2 ton. Pretty much period correct original. Danny T, from B’ham, Al
Hey guys, no one knows how to remove the seat bottom? I really would appreciate the help, if anyone knows.
The back has a couple of curved tabs that fit into slotted brackets on the rear edge of the seat portion.
Try lifting up on the back while pulling up on front edge of seat. Underside of seat frame has a few holes ( allows adjustment ) Metal frame around gas tank supports 4 brackets with raised pins to position seat.
A bit tricky with one person - best with 2
1940 Chevy KC 1/2-Ton
Authorized Pest
Authorized Pest
There are two Tech Tips regarding seats that *may* help some:
Easier seat adjustment
Seat Restoration
They may have some pointers that will help. They definitely have pictures!
Welcome to the site, BTW.
~ Peggy M
1949 Chevrolet 3804
Thank you Britcon and Peggy M.
This information was very helpful, although I still can’t get the seat to come lose. It’s obviously connected at the back, where the seat bottom joins the back, as you guys had said. But I still can’t get it to come lose. I’ll try again later
Moderated by  ndkid275, Phak1
