0 members (), 160 guests, and 5 robots.
Topics128,149
Posts1,056,818
Members48,456
#1463882 08/25/2022 4:36 AM
Just opened up the rear in my 46 1/2 ton. Looks like it hasn’t had gear oil in it since the last inspection sticker. 1973. Still have more tear down to do BUT…if it’s not salvageable is there a late model open driveline with 6 LUGS that is easily usable. Will wind up with a T5 trans more than likely if I have to go this route. I have new lowering springs and blocks set up for the 1/2 ton rear end and would like to use them as well. Significant investment. Staying 6lug as I just did the 6 lug front disc conversion.
Appreciate your input
Ed
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
1955 up to late ‘60s 1/2 ton. Some modifications required but not a deal breaker.
Early (2005 or so) Chevy Colorado had a rear axle with 6 lug wheels and a 57.5" track.
Depending on your budget and desired final build goals Curry makes entire rear end housings and axels and brakes, and can perfect match to our spring setup…very reasonable pricing when I looked…mine are 6 lug… you can get the exact rear end ratio you desire without the risks of chasing down dubious quality really old parts (you ARE going down the t5 path, might as well at least consider getting what follows it right on too?)
Was a pleasant surprise I found when I pulled off a rear hubcap on the 46 and saw their axel….and rear end…
Chuck
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
I've been running '65 Chev pickup rearend (fits inside the fenders) for years in my '46, lots of ratios available and still 6 lug. I'm sure there are many more options today, best of luck.
1946 1/2-Ton Chevy
