1 members (baldeagle), 26 guests, and 4 robots.
Topics128,037
Posts1,055,466
Members48,424
#1463814 08/24/2022 4:41 PM
I recall reading on here that some 1.5 tons had one-piece wheels. Going to check out a 1949 4400 today in hopes of finding serviceable wheels for my 1950 6400. Pics look like one-piece or locking ring - either of which is acceptable to me. Does any one know tire size for the 4400? I’m assuming its 7.5 -20 but I’m hoping it’s 8.25 - 20 or that the rim would accept that size.
MT1950 #1463815 08/24/2022 4:58 PM
Authorized Pest
Authorized Pest
Here's a Tech Tip on Wheels that may have some info that will help.
In there is also a discussion back to the forums about it.
I'm certain the topic has been discussed several times here. Try to search button in the menu on top.
Hope this helps.
~ Peggy M
1949 Chevrolet 3804
MT1950 #1463817 08/24/2022 5:12 PM
Thank you for the reply - yes, I’ve read the tech tips as well as Griggs’ pinned post many, many times over the years of searching for a solution to my wheel woes - I haven’t come across an answer to what size tire would fit on the rims from a 4400 but will look again.
MT1950 #1463824 08/24/2022 5:45 PM
I did find an 09 post from spanky that referenced a 1949 4400 with 8.25 -20s all the way around -if that was on the original 5” wide rims instead of the 6” wide on my 6400 I should be good.
MT1950 #1463826 08/24/2022 5:49 PM
Authorized Pest
Authorized Pest
Great!
(I sent a PM to Grigg, also. Maybe he'll respond!)
~ Peggy M
1949 Chevrolet 3804
MT1950 #1463874 08/25/2022 2:53 AM
The first year for the 1-piece tubeless rim was 1956. They can be found on the 4000 series trucks (the 6000 series had 6-lug) and will have the same 10-lug bolt pattern as your truck, but will have a 5.25" center hole...your truck has a 4.75" hole, so you'd need to make spacer rings to bring the hole back to 4.75".
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
MT1950 #1463908 08/25/2022 2:34 PM
I purchased two 5" wide rims with 7.50-20 on them off the front axle of a school bus. They worked great on the rear of my 46 2 ton, but they had holes for 9/16 studs in them. Just had to drill them out for 1/32" clearance for my 5/8" studs with a hand drill.
