6 members (Gdads51, 52Carl, Otto Skorzeny, dwreills, 55shaker, 32Fordpuchoptop), 70 guests, and 3 robots.
Topics128,036
Posts1,055,460
Members48,422
#1463727 08/23/2022 10:51 PM
' Offline
The picture shows the bottom of the plate that bolts to the top of transmission. Those four odd
bolts go up and through the plate and have nuts on top to attach the shift lever to that plate. Are
the bolt heads supposed to be 1/2 ground off, could they possibly have that much wear, or is it
something PO just put in there?
It's a '37 truck tranny according to the casting number.
It was likely riveted together before and some one had disassembled it to make a repair.
Fred
