1 members (Ole49GMC), 109 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#146365 04/05/2006 2:33 AM
Junior Member
Junior Member
I have a 1952 two-ton former firetruck with a two speed rear end. The master cylinder is leaking, and I can only find a rebuild kit for 1 1/4" diameter, but this system is 1 1/2". Does anyone have any leads on who makes a rebuild kit for this? Thanks
Your local auto parts store should be able to look in the specs. section of their brake book and be able to find the individual parts for an 1 1/2 bore. They might not find it under it's application. I rebuilt the master cyl. on my '48 2ton, and I think the local Bumper to Bumper ordered a kit and had it the next day. I don't remember if it was 1 1/4 or 1 1/2 though. Maybe fire trucks were bigger? Good luck.
Keith
If it were easy they'd have grade schoolers doing it!
I
I Offline
My 47 uses the 1 1/4 cylinder. I think I saw in the info from chevy that a school bus 2 ton used the larger 1 1/2 bore cylinder.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
I went to an automotive brake rebuilder for my old 1-1/2 ton brake hydraulics,and bought just the cup for about .90,and the cups for the wheel cylinders for .59 each. All the old boots and springs were okay. They had cups clear up to 2-1/4 inch.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
You can also find 1 1/2 ton Master Cylinder rebuild kit at Obsolete Chevy Parts Co. Their web site is www.obschevy.com. Kit lists for $16.95.
By the way.. the front wheel cylinders on the 1 1/2 ton use the 1 1/4 inch wheel cylinder whereas the backs use the 1 1/2 inch wheel cylinder. I see front kits listed, but not rears. I only found the rubber cups at my local NAPA store, so I had to polish the old metal pistons which luckily weren't pitted or scored.
Riding in the Passing Lane
Napa part # 209
1972 Chevy c10 Cheyenne Super
Bossman, weird, when I click on the link in your post, I come up with a Harley outfit (two wheel bolts), but when I Google "Obsolete Chevy Parts Co." I get the same address, click on it, and get the right web site???
There is a mistake in the link for some reason. Take the period out after the .com and before the slash. That makes the difference. I am not sure how it got there except I probably used a period to end the sentence and it got picked up when the link was made. I too got to a Harley site using the link as listed. If you take out the last period it works fine. Sorry about that.
Bossman - all ya gotta do is click the paper/pencil icon at the top of that post to edit it and fix the error! - then you can learn some more by clicking the edit icon on yer 2nd post and check the "delete post" box top left and click "edit post" to take it right out grin
