5 members (Gray_Ghost, Maybellene, Gdads51, TUTS 59, Hanks custodian), 77 guests, and 3 robots.
Topics128,066
Posts1,055,871
Members48,428
#1462602 08/14/2022 5:21 PM
1 Offline
I have a "stuck" front hub brake drum and am having some serious issues getting it disassembled. I was wondering if someone can share how to separate the wheel mounting hub from the brake drum. The nuts behind the wheel mounting hub have been removed since the picture was taken as well as the dust cap and crown nut/cotter pin. The wheel mounting hub has been beaten on with a sizable sledge but it doesn't appear to move at all. Brake Drum has also been "sledged" without results. Next step is to try a gear puller unless someone has a better suggestion.
'50 GMC 1 Ton Dually - Barn Find (sort of...no barn)
Red dot, center of chest ...
Have you backed off the brake shoes? Many times these old brakes will have grooves cut into the drum. The shoe wears with the grooves, causing the shoe to "lock onto" the drum. You have to back the shoes way off to get them to clear so the drum will come loose.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
1 Offline
if you're referring to using a screwdriver or prybar to loosen the adjusting wheel via the slot in the back...yes, I've tried that but it doesn't seem to loosen...in fact, it kind of feels like there aren't really any teeth left for the screwdriver/prybar to grab.
Thanks for the input !
It's possible, then, that the brakes have fallen apart and are in a jumbled mess that's jammed the drum. If you tap on the bottom of the drum with a hammer, can you hear anything moving around inside the drum?
Paul Schmehl CI 6
geek@stovebolt.com
1 Offline
I believe that they are still intact. Should the Wheel Mounting Hub freely come off the Brake Drum when the nuts are removed ?
I just finished doing this job on my '48 dually today. Right front wheel locked, brake adjusters frozen. Unscrew the cap on the hub, pull the cotter pin from the adjusting nut, remove the nut, use a good three jaw puller and slowly pull the assembly off. You'll have to fish the outer bearing out as you go but it's pretty simple. On mine there was rust on the shoes under the brake material that caused the material to separate from the shoes and jam everything up.
1 Offline
Thanks !...the puller was my next course of action...I'll move forward with it
Hit the drum in multiple locations and keep wiggling it. Paul is correct that the drum could be hanging up on wear grooves.
Hitting the drum will help it in getting past those grooves by vibration making it jump over them.
Jim
[img]https://www.stovebolt.com/ubbthread...A51D456-217E-4102-8B54-993B3C647DB7.jpeg[/img]
~ Jim Schmidt, Bucks County, PA
1953 Chevrolet 3804 1-ton
In the DITY Gallery
Offline
Offline
Stuck as in won't come off or stuck as in won't rotate, either? Sledging your hub won't do anything. If it DOES NOT rotate, sledging the drum will, but it takes 2 people. One to sledge the drum at the locations of shoe contact, and the other person standing on the 6 foot spud bar between the studs trying to rotate the drum. Install your spindle nut and snug it before trying to rotate it. For a one man job, you can use a wrecking bar (or equivalent) between the studs and put a floor jack under it to achieve the same effect. If it still won't rotate and you have a cutting torch available, evenly heat the entire outer surface while under tension. It will have to get pretty hot to pop, though! If your shoes are rusted to the drum, the expansion of the drum from the heat will cause it to break free of the brake lining. Let it cool to ambient temperature before you do anything else, or you'll warp it, though
If it DOES rotate, then there is a ridge on the drum that you'll have to get it past. (As Baldeagle mentioned) The star wheel just rides against the spring, so it may feel like there are no teeth in it. Get a light and look inside to see what you can see. Reference the position of the wheel, try to move it and look again to see if it has moved. If it moves, keep moving it until you can see that the threads are either appearing or disappearing. (You want them to disappear) Most likely the threads will be rusted and if it does turn, it will only collapse so far.
If it's rotating and you cannot get the adjuster to release, then get the puller. Remove the spindle nut. Sledge the drum while you have it under puller tension. (It helps to put a jack under the hub to maintain the proper height to avoid binding. If you still can't get anywhere, release the tension and cut the heads off of the hold down pins and try again.
My 1955 GMC 450 Dump Truck
Elderly Iron
"Performance" is the pursuit of a toy that won't break.
Crusing in the Passing Lane
Remember, one bangs knuckles on bottom of spring when tightening brakes, so go opposite way when loosening brake shoes!
Ed
EdPruss #1463090 08/18/2022 9:17 PM
1 Offline
Success !...using the puller brought the Brake Drum off with ease...thanks to all for your input
1950 FC253 #1463149 08/19/2022 11:25 AM
Not sure why you needed to pull that apart, looks to be in fine working condition! ohwell
Your perseverance paid off! Nice job!
Now get them like new!
Jim
In the DITY Gallery
62401
Wow -- excellent view/illustration of the classic uneven shoe wear on Huck Brakes. You can either swap them around and put the worn shoe where the unworn shoe is, or just get the worn shoes relined.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
1 Offline
not to change the subject of the thread...but what is the difference between 3800 and 3804 ?
3800 indicates the 1 ton truck series, and 3804 indicates it's a pickup (versus flat bed, chassis/cab, etc.)
Last edited by klhansen; 08/22/2022 7:27 PM. Reason: added page from Vehicle Info Kit
Question:
Can you remove the wheel spacers and run a non-1ton wheel?
Originally Posted by 58-1-ton-dually
Question:
I would like to know this as well.
Can anyone confirm if there are differences in the srw vs drw hubs themselves, or is it just a matter of bolting on the wheel spacer to convert a srw to drw?
Liquidated my projects
Now looking for a decent '47-'55.1 3100, 3600, or 3800
1950 FC253 #1474647 11/10/2022 12:29 AM
2 Offline
I don’t know about 1958
But I do know 1948-54 the answer is yes
The only difference for a DRW is the stud length is a tiny bit longer for the extra thickness of the rims and that round nut plate that goes over everything under the nuts
It’s pseudo common up in Canada to see a DRW truck with the single rear wheel style front wheels
Because the truck started life as a single rear wheel
And someone just got the dual rear wheels
And omitted the extra round spacer plate that normally comes with DRW and just bolted the duals down with barely enough threads
I have seen a couple trucks this way at the junk yards and I also own two that have had this treatment done to them before I got them
-s
#1501172 05/17/2023 9:32 PM
Moderated
Moderated
Thank you so much for your information. My 1950 1 ton dually has the nonrotating stuck front wheel also. I've banged with a hammer, heated with a torch and squirted power blaster by the pint in the adjustment holes in tha backing plate without luck so far. I was intrigued by your "sledging the hub" idea, but can't quite figure out what "sledging" means (pardon my ignorance-I'm still a newbie here. May I ask what this means? Thanks so very much!
No you can’t simply remove the spacer to run different rims. The extended hub contains the bearing and bearing race. There are different front hubs for single/dual rear wheel applications
1949 gmc 1-ton
Moderated by  Dusty53
