5 members (Bill Hanlon, Southerntruck, UtahYork, 55shaker, FAST55), 78 guests, and 4 robots.
Topics128,056
Posts1,055,803
#1462355 08/12/2022 5:02 AM
The clutch pedal in my '55 series II pickup is all wobbly ( side to side) and scrapes the metal floor board. Very annoying. Everything under hood seems tight. Is there a rubber insert for the hole in the floor so it tightens the pedal and stops the scraping?
Jim
1955 series 2 Chevy 3100
Take a look at the pedal lever bushing area from under the truck while someone else wiggles the pedal for you. I'll bet your bushings need replacement.
The only other possibility is a loose bolt which holds the pedal rod to the pedal lever.
My grandson is coming over tomorrow. I'll check it out.
Jim
1955 Chevy series 2
6 cylinder, 3 on the tree
Short bed, step side
Curmudgeon
Curmudgeon
Part number for seal is shown in drawing.
Could also be loose nut on pedal assembly (upper).
O Online: Content
Or a loose nut behind the wheel.
1950 Chevrolet 3100 (Ol' Roy)
More than likely.
Jim
1955 Chevy series 2
Anyone who thinks its a good idea to spend the time and money with unbridled enthusiasm on this hobby (as we all do), suffers from that particular malfunction.
