3 members (Hotrod Lincoln, Charles in CA, 1 invisible), 89 guests, and 4 robots.
Topics128,261
Posts1,058,342
Members48,485
#1462496 08/13/2022 3:48 AM
Hi, what types of screws connect the grill to the gravel pan? My grill is new. Is it nuts and bolts or screw clips and screws? I couldn’t find it in the assembly manual. 1950 Chevy truck. Thank you
1950 Chevy 3100
Jason
1950 3100
I'm pretty sure the connection is made by clip nuts and hex head sheet metal screws from the bottom. IIRC, the screw size is #10.
Unfortunately the assembly manual is for '54 grilles.
It is nutplate clips (large tinnerman clips)- with sheet metal screws that have hexagonal heads. True value hardware had both of these, when I put my grill on several weeks ago
~ Dave
Thank you. The screws came with the bolt kit I got…I think. But no clip nuts. Much appreciated
1950 Chevy 3100
Jason
1950 3100
