7 members (Opelika Tom, Bigdogg, panel fan, 52Carl, carbking, 1955 1 Series, moparguy),
347
Mod | | | Forums66 Topics128,164 Posts1,057,083 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2018 Posts: 167 'Bolter | | 'Bolter Joined: Feb 2018 Posts: 167 | Hi, what types of screws connect the grill to the gravel pan? My grill is new. Is it nuts and bolts or screw clips and screws? I couldn’t find it in the assembly manual. 1950 Chevy truck. Thank you | | | | | Joined: May 2015 Posts: 11,156 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,156 | I'm pretty sure the connection is made by clip nuts and hex head sheet metal screws from the bottom. IIRC, the screw size is #10. Unfortunately the assembly manual is for '54 grilles.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | It is nutplate clips (large tinnerman clips)- with sheet metal screws that have hexagonal heads. True value hardware had both of these, when I put my grill on several weeks ago
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Feb 2018 Posts: 167 'Bolter | | 'Bolter Joined: Feb 2018 Posts: 167 | Thank you. The screws came with the bolt kit I got…I think. But no clip nuts. Much appreciated | | |
