3 members (Shaffer's1950, Wally / Montana, 1 invisible), 46 guests, and 1 robot.
Topics128,090
Posts1,056,022
Members48,430
#1462434 08/12/2022 7:42 PM
Since I removed the truck bed boards for refurbishing, I thought I would power wash the dirt/crud off. Off to the car wash I went. O'Reilly's was right next door. Purchased these two items and sprayed everything I could get to. Wow! Stuff worked real good!
1953 Chevy 3100
I have recreated my Dad's old work truck with a 5 window.
My crud was so bad I needed to scrape wire wheel am then spray with cleaner before power washing.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
Dang, this is fun!
1953 Chevy 3100
Simple Green is good stuff! I've used it also.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Here's what 68 years worth of crud looked like on my 54. There's still black paint under there. Scraped off a five gallon bucket full just off the frame. Filled two holes in the path.
Crud anyone?
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
O Online: Content
Hey! you're ruining the "patina". That original crud makes it more valuable.
1950 Chevrolet 3100 (Ol' Roy)
And rust needs air so maybe that oily mud/crud keeps these old trucks preserved.
1957 Chevy 3200
Daily Driver
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights.
Follow in the DITY
O Online: Content
It does. Plenty of vehicles are saved from rust by leaking engines and transmissions that coat the underside of the chassis. It forms a waterproof layer that keeps getting thicker over time.
It's better than Ziebart!
Interesting to read! When I scraped off the grease, the undercoating basically fell off revealing beautiful shiny black paint on the frame and the front cab mounting brackets were pristine. The smile on my face almost cracked my jaw.....crazy what can make a grown many happy.
Ron - - Dusty53
1954 Chevy 3604
7
7 Offline
I buy the regular Super Clean and use it on everything. I had some old valve covers that were covered with grease and the inside had old burned on oil. I sprayed them down and washed them down and they were clean. Good stuff.
1946 1/2 ton
Jethro I think you'll find that black paint is actually tar,50 yrs. ago they had chassis coating to put on the frame to protect it that was a mix made for that. Haven't seen it but probably still out there,was for just run of the mill repair.
Naaa. This is paint. When I scratch it there is shiny steel under it. At any rate, the inch-thick coat of nasty greasy crud hides a durn near perfect chassis.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
Get a wirewheel to go onto your grinder and go after it again. You will be amazed at how much stuff comes off again. Then soak it in oven cleaner and powerwash. My frame came out amazing.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
