5 members (Bill Hanlon, carbking, HandyAndy, dt235sd, Otto Skorzeny), 91 guests, and 3 robots.
Topics128,053
Posts1,055,777
#1461570 08/06/2022 12:53 PM
I thought I would run this by you guys before buying. They are 19.5 wheels and tires $75.00 each and close to home. I am currently running 7.50-20” on my 4400 1 1/2 ton Chevy.
If I get adapters I could sell my tires and rims to lower the price of these , so what do you think?
1950 4400
Joe Allen Sounds OK On the adapters I don,t know what holds them in place. I have some later wheels I thought I might use that way. Really havn't looked at it yet,hear others do it so must be possible.
fixite7 #1461745 08/07/2022 10:05 PM
Yes I remember seeing some for sale but I can’t remember what the name of the company is
1950 4400
19.5" tires and rims are not in the same class as your 20's...they might look small on your truck. The tubeless one piece rim that matches your 20's is the 22.5" rim.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Can the 22.5 be adapted to fit without cutting and welding?
1950 4400
Without cutting or welding what?
What year is your truck?
This rim might work, but it has the large 6.25" center hole...you might need to have a spacer made depending on what year your truck is...early trucks had a 4.75" hole.
https://buytruckwheels.com/collecti...ite-steel-10x8-75-old-chevy-2-ton-trucks
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
1950 4400
1950 4400
I’ve seen people cut out the center of their old rim to weld in the center of the newer rim
I can’t see paying $2000 for rims and then tires on top of that. This definitely won’t be a daily driver.
Do you know what the height difference is between the 19.5 and 22.5 wheels?
1950 4400
The wheel height difference would be 1", but that's not what you need to know, your looking for tire diameter (overall height of the tire). I don't think there are any 19.5" tires that are 40" tall.
I don't know what the common tire sizes are for the 19.5 rims, you'll need to search that.
The original match for your 7.50x20 would be the 8.25x22.5, (but I don't think they are made anymore) so you'd have to go up to the 9R22.5 which are about 40" tall.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
My '59 Viking 40 has 19.5's on it. I'm assuming the originals on it were 20's also. You can look at it in the gallery forum and decide for yourself if you think they look too small. They might be a little, but I'm ok with them. To each his own.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Thanks Rich
1950 4400
thumbs_up
Rich
1947 Loadmaster
