9 members (Alex52, 1955 1 Series, 66flea, Frank50, Shade Baby, FAST55, jay d, Eric P Jr, 1 invisible),
86
Mod | | | Forums66 Topics128,188 Posts1,057,220 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 16 Apprentice | | Apprentice Joined: Jan 2006 Posts: 16 | im wanting to pull the factory 2speed rear out of my 42 ton and a half...im wanting to replace it with a later model 1 ton chevy rear ...anyone done this ????i know that ive got a rear out of a 84 cab&chassis and they are a little shorter than a dually rear the rear i have is about 2inchs to short.... | | | | | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | This is a pretty simple swap, are you gonna get rid of the dually rear wheels?
Later dually rears are pretty close in width.
Be careful to keep yourself in a useful power band if you're gonna use the truck for work at all. | | | | | Joined: Jan 2006 Posts: 16 Apprentice | | Apprentice Joined: Jan 2006 Posts: 16 | the truck has new small block and 400turbo trans...yes im gonna use dual wheels it going soon to get a custom car hauler bed put on | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | If you're going to make a car hauler why are you lowering the carrying capacity. Why not leave it as a 1-1/2 ton truck? If you want higher speeds add a overdrive unit or put a 2-speed rear in. My 2-1/2 ton wrecker with a 350 SBC, SM420 trans and a 2-speed rear will run 70+ mph. My fire truck will run in the low 60's after I swaped in a 2-speed rear...before the swap it would max out at 53 mph. I paid $250 for the fire truck 2-speed rear set-up. Mike B  | | | | | Joined: Jan 2006 Posts: 16 Apprentice | | Apprentice Joined: Jan 2006 Posts: 16 | mike the truck already has a 2 speed rear in it ...im just wanting to bolt in a later model 1 ton rear out of 80s-90s chevy 1 ton | | | | | Joined: Dec 2004 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 60 | I know an overdrive system will help with higher speeds but a 2 speed rear should not, it only makes it easyer to pull a heavy load from low speed, right? I know this from my 1.5 ton truck. The orriginal owner put in a two speed thinking it would make him go faster up top but the truck still maxes out at 45-50 mph. It will haul a house though  | | | | | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | "ur2 slo" is correct, Most 2 speed rear ends will only change your top end speed by 4-5 MPH if evan that on my 46 I looked in to a 2spd rear end and it only changed my final drive ratio a vary small amount
2 speeds work best for split shifting on a hill with a load | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | Like any single speed rear, the 2-speed rears are available with many different gear ratios. You need to do your homework first, the past owner might have installed a rear that has a lower ratio. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | My experience with 2-speed rears on these old trucks is that the second speed is deeper than the standard rear and intended for getting a heavy load moving. I've never seen one era correct that would allow you to go faster than your current high.
Something you might look at is one guy swapped the ends of the axle housing to the newer axle and then redrilled the hubs so the newer axle shafts which bolt up, allowing running the original brakes and wheels while having a later axle ratio. Do some searching and you should be able to find that thread here on the Stovebolt.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
