2 members (jay d, Gdads51), 75 guests, and 2 robots.
Topics128,265
Posts1,058,360
Members48,485
#1461544 08/06/2022 1:22 AM
Hello Stovebolters,
Just purchased a 47 Gmc FC102. I owned a 47 3100 previously and it was a standard 3 speed. This truck has a 4 speed (muncie) but next to the soft knob is a lever (photo attached) Newb questions: 1. What 's the lever all about? Is that for shifting into reverse? 2. The previous owner said that the tranny is non synchronized in all gears, in going thru the gears on the road it doesnt drop into gear like my previous, there is some lite grinding before things mesh up. In researching this, looking over previous threads the muncie 4 speed should be synchronized in gears 2 thru 5. Could this grinding ( lack of synching up) be because the PO didn't use 90w mineral oil in the transmission? Thank you for your help!
Al
1947 GMC model FC102 original drivetrain 216 eng sm420 4 speed.
I guessing it's for a 2-speed transfer case. High And low.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Looks like you have a early 1947 model truck. That lever is for the non-synchronized transmission reverse lockout.
Lots more pictures
What you have is affectionately known as "The Crashbox" 4 speed. No syncros in this beast, double clutching is the order of the day driving a truck with this trans.
The lever is your reverse lock out.
Steve
Steve
1946 1/2 ton
Your going to become a expert in double clutching.
