4 members (HandyAndy, '37 barn find, cmayna, ESum), 117 guests, and 6 robots.
Topics128,210
Posts1,057,465
Members48,471
#1460573 07/29/2022 12:34 AM
How do you remove the Gas/fuel gauge. I have new one to install. Anybody have step-by-step or photos?
1953 Chevy 3100
I have recreated my Dad's old work truck with a 5 window.
Moderator, Electrical Bay
What year, style, etc? There are some differences...
~ Jon
1953 Here is a picture.
1953 Chevy 3100
4 studs attach the gauge cluster to the dash. The nuts that hold the cluster in area accessed from the back of the dash, then the cluster comes out from the back.Once it's out, you'll see that replacing the gas gauge is pretty simple.
Here's a couple photos of the cluster in various stages of disassembly. You can see the tabs that attach the cluster to the dash. The gauges are held in place by screws from the back in most cases. You'll see how once you get the cluster out.
AD Addict & Tinkerer
The bezel is crimped in a few spots which holds the assembly together. Using a small screwdriver, carefully pry open the crimps. Once the bezel, glass and inner trim are removed the gauge is visible. To remove the gauge, the adjacent gauges need need be loosened. There are two tabs (visible in the picture) that are behind the adjacent gauges and will prevent you from removing the gauge.
When you reassemble Some of the reproduction gauges are made slightly thicker and the needle gets caught on the inner trim piece inhibiting the needles movement, making the gauge look like it’s not functioning. If you find this condition, a gentle push with your fingers will give you the additional clearance you need to keep it from binding. Mind you I do mean gentle as it moves easily and you don’t want to distort the inner trim piece. Once you have determined the needle moves freely, reassemble the rest of the cluster. The first time I installed the bezel, I used a screwdriver and a small hammer to crimp the bezel to the cluster and I felt it jared the cluster too much. The second time (yes, it took two times to get it right) I was able to use a needle nose pliers to get the crimps in. Protect the chrome from getting marred. Maybe some other “Bolters” have some other ideas on how to crimp the bezel on to the cluster. Now reinstall the cluster and hopefully it works!
Phil
Project Journals
Stovebolt Gallery Forum
I just use needle nosed pliers. Many years ago I actually had a pair of pliers which were made for stuff like this. They resembled hog ring pliers a little bit, but I haven't seen them for at least 20 years. One jaw was straight and one was curved and they worked like a champ. You don't need much, though with this trim ring. Oh, and if you get a replacement trim ring it will be chrome plated (not polished stainless) and the chrome plating will pop off when you crimp it. Good luck.
~ Jon
Moderated by  ndkid275, Phak1
