4 members (Hotrod Lincoln, Guitplayer, TUTS 59, IHPWR), 185 guests, and 1 robot.
Topics128,108
Posts1,056,227
Members48,436
#1454247 06/06/2022 10:55 PM
DO NOT order a standard size king pin set for a 1 ton without confirming that the replacement pins are in fact .921 in diameter.
Not all but most suppliers will show in the catalogs they will fit both 3/4 and 1 ton, I ordered a set from truckandcarshop.com that I was told they are guaranteed to fit a 1 Ton, they do not!!!!!!!!!!! .866 is what I received for a 1/2 ton. Because I had taken the bushings and spindle to a machine shop to ream I now have a $60. set of steel drift pins and a full set of bushings that if reamed to .921 would likely have no bushing material or grease channel remaining.
I've called multiple vendors and searching online and even if they are in stock they are .866 1/2 ton pins not .921 although the catalog lists as fitting a 3/4 or 1 ton.
I've had lots of "HUH", "WOW" and even a "OOPS" moments when the parts person actually gets it, whether or not they will get a IT geek person to change the listing is for another discussion.
I did find today 1 supplier that has 3 complete sets in stock although they are at a much higher price at least he has confirmed them to be .921 standard size.
Should be back on the road in a week.
Doyle
1950 Chevrolet model 1434 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
You will never stop learning new things, no matter how old you are.
H Online: Content
Do the pins have any oddball shapes or features that can't be duplicated by common machine tools? It sounds like there's a market niche that's just begging to be filled by someone with a lathe, and possibly a milling machine handy. How about sending me one of the pins you're replacing for some R&D on tooling up to make a limited run of them?
I feel your pain, run into the exact same issue. Ordered two both claiming to be 3/4 & 1 ton; both clearly 1/2 ton. I haven't tracked down the correct size yet although there was another post on the subject and he listed a vendor that also has the .921" (FCRC Machine). I should probably try again to order a set - third time's the charm right.
HRL when I get around to mine, happy to donate the old ones if you don't have any then.
1949 Chevrolet 3/4 Ton - Still Solid. Regular Driver
OT Vehicles:
1925 Hudson Brougham Super Six
1950 Chevrolet Styline (Parts)
1952 Canuck Pontiac Sedan Delivery (Well Underway)
1973 F250 4x4 Highboy
1977 F250 4x4 Lowboy
H Online: Content
Thanks! I can't imagine why a good quality piece of round steel stock of the proper alloy couldn't be turned into a serviceable king pin by anyone with the unmitigated gall to call himself a "machinist". There are at least two or three guys here at Stovebolt that I'd be comfortable with betting my life on a part they fabricated.
There's an NOS Kingpin set available on Ebay right now, worth the money and yes its the correct part number. I'd jump on it.
https://www.ebay.com/itm/125263072209?hash=item1d2a42cbd1:g:ypcAAOSwxxpiWrt-
Ron - - Dusty53
1954 Chevy 3604
The king pin listed on the Ebay site listing is for the .866 pin the standard size of pin for a 1 Ton is .921
I'm ordering a set from a vendor in Ontario that has confirmed it is .921 pin size, once I have it in my hand and confirmed the fit I'll send you the vendor information.
The GM NOS Kingpin set on Ebay that I referenced is the correct part number. It is listed as the correct part number for 53-55 1st , 3/4,1 and 1 1/2 Ton.
I have a GM # 3704112 Kingpin set and the pins do measure .921" . I don't know where the .866" you referenced comes from. I understand that the GM Parts list text has 5 5/8 long x 15/16 O.D. ( .9375") but the pins in my set actually do measure .921. Hope this helps.
Ron - - Dusty53
1954 Chevy 3604
1 Offline
I found on old receipt in my box of spare king bolts for my '51, 1-ton pickup, chassis designation JSF. Here's the NAPA part number dated 4/17/03: 262-1161.020. I ordered two sets because my local store had to special order them from NAPA. I know this is old but it might be a start. The standard part number would end with 1161. The .020 is because they are .020 oversize. That may be why they had to be made to order. Two sets came in one box and the invoice is for $105.80 list, $80.90 net and $10 freight. It's not clear who NAPA got them from. Perhaps Precision Engineering. Their name appears on the box along with the part number.
1951 3800 1-ton
In the DITY Gallery
doyle1950,
So they were "guaranteed to fit". What does that guarantee entail? Did they give you your money back?
1950 Chevrolet 3100 (Ol' Roy)
For what it's worth: Classic Parts has a King Pin set for 46-52 3/4 & 1 ton. Has the .921 dia. pin. There part number 74-113.
Tom
Heres the ones i scored off ebay for my 3/4T. You will also need to ream them to fit. I have seen both of these on ebay several times. I just bought mine justvover a year ago. That part number might help you.
I'm a machinist and making a king pin one off that was right would be near impossible. They need to be heat treated per GM specs, if you knew what the alloy was. The best and easiest thing is keep digging to find the correct pin.
H Online: Content
Custom gunsmiths have been heat treating parts since the days of Brown Bess muzzleloaders in the 18th. Century, or before. Using a Brinell hardness tester is not rocket science, and neither is using a rosebud torch and some Kasenit powder. The only places that might need to be tempered are the ends where the bushings ride, and those don't need to be brittle- - - -just surface hardened.
If it is going to be a WORKING truck I'd follow specs but if a cruiser or show piece anything should work. Should be very easy to turn from a piece of 1" bar stock and don't worry about accurate to five places as the BUSHINGS can be honed on a Sunnen to correct clearance. One hour job. My centerless grinder went with the big shop but I still had they would be as accurate as the instrument doing the measuring.
Evan
I bought a king pin kit from Chevs of the 40s late last year for my '52 GMC 3/4 ton. Their part number is 601019. The web page did not have dimensions, so I e-mailed asking. The right answer came back, "The 601019 are .920 X 5 1/16 and the bushing is 1.06 OD"
I ordered
THIS
[img]https://www.chevsofthe40s.com/images_product/large/601019.jpg[/img]
Fit just right.
... also ...
I have a used one time .921" reamer for rent. The guy at the machine shop says it worked great. I haven't done the left side yet, so I'll need it back. Price is $50 (gladly refunded when I get it back) + shipping.
If you guys are still looking, I ordered a kingpin set off of Rockauto for my 54 3800. It was a few years ago and I was able to get an AC Delco kit, I might have the part number still. They still offer one with a .921 pin that's being sold by Moog.
1954 Chevy 3800 Long Bed: ex-fire truck turned farmer's town run about turned 353T powered retirement project
1953 Chevy 6400: the work truck
Thanks, I'm satisfied with the set I ordered from Bill's Truck shop in Ontario.
Now to try to find a speedometer gear that will work with the upgraded 4:10 gears I just installed!
Regarding the speedometer gear mentioned by doyle1950, many years ago when I changed the differential gears in my 1958 1/2 ton panel truck (went from 4.11-1 to 3.80-1), I went to a local speedometer shop for help.
They calculated the gearing that I needed vs. what was in the truck from the previous gears (stock) and built me a little adapter that on one side screwed into the side of the transmission and on the other side accepted the speedometer cable.
That little adapter (a tiny gearbox in itself) made the speedometer read correctly. I was a very happy camper!
Cheers, Dean
Dean 'Rustoholic' Meltz
Lurch: 1927 1-Ton Chevy Cattle Truck
Old and ugly is beautiful! -- The Saga
Lurch's Gallery
Justin: 1928 Chevrolet AB Canopy Express
Back in the day GMC sold a wide variety of those adapters in the parts department. Here is the list:
Moderated by  Dusty53
