0 members (), 89 guests, and 4 robots.
Topics128,271
Posts1,058,313
Members48,485
So , I was looking into a 6 lug front disc brake conversion kit for my 1953 ,3 speed manual. Cpp tells me that the brake booster will not work for frame mount , because crossmember being in the way. They tell me just to use the master cylinder ? Have any of you done anything differently for under frame mount with brake booster?
1953 with a 216
AD Addict & Tinkerer
iI had the same question a few weeks ago and came to the conclusion that I would need to buy the kit and figure out where it needed to be located and/or modified. One possible solution and at the top of my list, as suggested by a fellow ‘bolter “Coilover” who own’s and operates a body/hotrod shop in Texas, was to move the whole setup (booster & MC) back on the frame, then make a longer rod. Another ‘bolter said he was able to grind the offending section on the rear crossmember. I have also heard that you can buy a new tubular crossmember that eliminated the interference.
Phil
Project Journals
Stovebolt Gallery Forum
Curmudgeon
Curmudgeon
I hate to do this to CPP but there is another headache and I know this complicates this topic, but it involves safety.
The CPP master cylinder is Asian made and there is a possible reliability issue:
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1459439
Look around at other vendors like speedway……many of the proportioning valves appear to be the same parts. Appear is the key word as there little documentation on the parts.
https://www.speedwaymotors.com/GM-Disc-Drum-Proportioning-Valve-for-1-2-20-9-16-18-Outlets,9878.html
