9 members (GMCJammer51, Materman, Lightholder's Dad, Ridgeback, Brian Moore, tclederman, jupitor, treegrower, 1 invisible), 189 guests, and 2 robots.
Topics128,080
Posts1,055,952
Members48,430
#1460591 07/29/2022 2:47 AM
My newly acquired 53 pickup has S/N 0304213 on the block below the distributor and the cast date appears to be D204. What displacement is this and is it a truck motor. It is painted light blue.
1953 Chevy 3100
I have recreated my Dad's old work truck with a 5 window.
Sorry. I don't have an answer for you. Try posting your question in the Engine forum, or maybe Genral Truck Talk.
Also, when you get a chance, post some pictures of your truck.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Go to the tool bar at the top of every page and click on “Tech Tips”. Go to “Identifying your truck” and scroll down to “Deciphering your VIN” by Barry Weeks. You can find your info there. May or may not work for engine numbers.
D204 Should be April 20, 1954
BC
1960 C60 pasture art
We need more info to help...find the engine casting number found just above the oil pan on the front right side of the block (may require a putty knife to clean out the recess it's found in). That will help us determine what decade your block was cast, date code D204 could be April 20th of 1944, 1954 or 1964.
Also, post a picture of the stamped serial number 0304213.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I am new to this forum and don't know how to post photos or if I can yet.
1953 Chevy 3100
Instructions for photos are in the left margin of every page.
Here are the numbers on the pad below the distributor. 0304213T54Z.
1953 Chevy 3100
Redbird, as I answered in your other thread, the engine number suffix T54Z the engine is a passenger car 235 originally mated to standard transmission.
The T shows the engine was manufactured in the Tonawanda, NY plant. 54 is the model year of the car in which the engine was originally installed. The Z designates a passenger car "Blue Flame" 235, originally mated to a standard transmission and rated at 115HP. That engine would have a solid lifter camshaft, and the block will not have been drilled at the factory for the oil gallery needed to run hydraulic lifters. It's a good engine. I have a similar F54Z in my '53 (only difference being it was manufactured in the Flint, MI plant).
I answered you other questions in your separate thread.
Doug
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
