6 members (GDW, Gdads51, Shade Baby, Shaffer's1950, 3B, 1 invisible), 143 guests, and 3 robots.
Topics128,139
Posts1,056,459
Members48,441
Picked up a nice grill surround at an auction for a 47-53 GMC. The question is: Will the surrounds fit both the pickups and the big trucks? It seems like I remember there was a difference in the hood and fenders but I can’t remember what the story was on the grills. Any guidance appreciated!
If you are asking about 6.1068 below, the answer from the 1939-53 GMC Master Parts Book is that there are 3 different parts used depending on models 350 and smaller. I'd guess that larger than 350 series would have their own.
Thanks! I’ll check it out tomorrow to see if I can find the numbers.
I doubt you'd find numbers.
Someone like Crenwelge could probably tell you the difference. He probably has more than one of each in his yard.
Chevy Grilles are different between 1/2 thru 1 ton and 1-1/2 ton and larger. I'd be very surprised if a GMC grille surround would fit both the smaller and and larger trucks.
1 1/2 ton , and larger trucks have taller grilles, so the grille surrounds are also taller.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Put a tape measure on it this morning, and read it as 17 1/2 to 18 inches tall near the end.
Can anyone compare this against their grill? Thanks in advance!!
I’m pretty sure it’s not for the small GMCs. Thanks to those who helped me on this.
