0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1459007 07/16/2022 11:43 PM
A thread in the General arena was about a superb AD (One Exceptional Build). It referenced this link.
https://bringatrailer.com/listing/1950-chevrolet-3100-33/ (link may go away)
I think the white walls are too wide! I've seen some that are even wider which appear to dominate the entire side of the tire and the appearance of the truck.
In 1962 I bought 4 new white walls for my '51 Chevy from a Chevron station where I worked (forgot the Chevron tire brand name). Here's what I think the width of a white wall should be. Picture taken in about 1965 in Laramie.
The good news is that tires are probably the easiest thing to change on a vehicle….!
I was more concerned about the drivetrain whining he had while driving it- is it the transmission or rear end? I never got to drive my truck before I swapped out the rear end and transmission for something more modern….did these trucks whine that badly right out of the dealership?
~ Dave
AD Addict & Tinkerer
The whine sounds just like my ‘52 3100 with a ‘59 235, original tranny and torque tube 4:11 rear end. Once you get to third gear the whine goes away.
Phil
Project Journals
Stovebolt Gallery Forum
Curmudgeon
Curmudgeon
Did you notice the new VIN tag that wasn't stamped correctly?
Whitewalls! Check these out. Cat's meow.
There was no factory whitewall option for a 50 AD truck.
Dealerships would install whitewalls if you pay for them.
Keeping them white was constant maintenance.
Late 50's began the hot rod era where anything goes including chrome flipper hubcaps.
Ah, Chevron stations in western WA branded their tires Atlas
Remember Atlas Bucron tires? Early 60's version of street slicks.
Insomniac
Insomniac
Port-o-walls have the Atlas name on them.
www.youtube.com/watch?v=zc7wKEBy0ac
Gord 🇨🇦
1954 1/2 ton 235 4 speed
How on earth do you get those things perfectly centered?you’ll end up with “clown car effect” on the road, wont you?
~ Dave
As kids, we called those "Mickey's" as in Mickey Mouse.
Curmudgeon
Curmudgeon
I'm old enough to remember those. Okay when new but would show a gap as they aged.
Usually found them on a poor man's Cadillac. Flapping in the wind on the highway.
There is no "right" answer.
First off, nobody that purchased a new AD truck ordered whitewall tires. These trucks were used for actual work. I would love to see a period photograph of a new AD truck in a dealership equipped with white wall tires. It ain't gonna happen.
The whitewalls in your photo look like 2 3/4" WW.
White walls were already being narrowed by carmakers in the mid 1950s. My 1956 Cadillac came equipped with blackwalls or 2 3/4" whitewalls if ordered. You could still get the wide whites up to about 4 1/2" but they were falling out of vogue.
White walls on trucks were just a waste of money for farmers and contractors and other people who used a truck as a truck.
1950 Chevrolet 3100 (Ol' Roy)
To admin and other users:
The video link in the above post is embedded. It’s possible to edit that post so the video is not embedded
1. Edit by backlighting that web address and cutting. That will put the link in your computer clipboard.
2. Using the FULL EDITOR OPTION, put the cursor where you want the link to appear within the post.
3. Click the icon at the top of the page that looks like a WORLD WITH A CHAIN LINK. A special window will appear on your screen.
4. Erase the https:// characters in the text area so it appears blank.
5. With your cursor still in the box of the special window, hit the CTRL key and V key on your keyboard simultaneously. This will paste the web address into that box.
6. Click ENTER. The box will become blank again and you can type in the name you want to give your link, such as VIDEO LINK, or LINK TO VIDEO.
7. When the post is finished and signed, the link should appear on the screen for others to click and view, but the video will not be embedded.
$56,000!
That's a beautiful truck but not that beautiful!
With the recent change in the site’s system videos are able to be posted. Site owners are working on trying to disable that feature. Members should refrain from the temptation to post videos. Links to videos are welcome. Thanksu
I wonder if Diamondback could reproduce those tires!
