1 members (Shade Baby),
21
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | is it necessary to prime an inline fuel filter? My truck won't start after replacing old fuel filter. Thanks. | | | | | Joined: Jan 2014 Posts: 3,677 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,677 | Are we talking an old truck with a mechanical fuel pump and a carburetor? And if so, is the filter located before or after the pump?
I’ve never primed mine.
1951 3100
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Scottss60, it would be nice to know what truck you’re working on. Thanks
| | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | 53. It started right up this morning. I changed the inline filter and drove about 1/2 mile and died. Cranks but won't turnover. I can see fuel in the filter. Tried starter fluid into the carb but didn't start. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | New gas tank or old gas tank? If old it may have crud floating around in it. When the crud gets close to the fuel outlet the fuel pump sucks the crud up against the fuel outlet and shuts off flow. Let it set awhile and the suction releases and fuel flows again.
| | | | | Joined: Feb 2016 Posts: 1,982 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,982 | If it wouldn't fire on starting fluid you have an ignition problem, or lost the timing chain.
| | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | 54 engine, filter located after pump. | | | | | Joined: Feb 2016 Posts: 1,982 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,982 | Oh,ok, no timing chain then. Turn the filter end for end, maybe it has a check valve built in and can't push gas through.
| | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | If it doesn't fire on starter fluid then look somewhere else. I use a spark tester like: https://www.amazon.com/Lisle-20610-Inline-Spark-Tester/dp/B0002STSC6
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Martin Before I new any better had cut a steel tank line put on neoprene hose. One of those round spider nests got against that steel line and would act like a check valve. Now use a much better fuel,start,run,ride,drive,easy to trouble shoot,no vapor lock,no fuel pump,big filter !!! | | |
