2 members (Peggy M, UtahYork), 62 guests, and 1 robot.
Topics128,035
Posts1,055,443
Members48,422
#1459190 07/18/2022 4:01 PM
is it necessary to prime an inline fuel filter?
My truck won't start after replacing old fuel filter.
Thanks.
scottss60 #1459191 07/18/2022 4:04 PM
Are we talking an old truck with a mechanical fuel pump and a carburetor? And if so, is the filter located before or after the pump?
I’ve never primed mine.
1951 3100
scottss60 #1459195 07/18/2022 4:10 PM
Scottss60, it would be nice to know what truck you’re working on. Thanks
JW51 #1459198 07/18/2022 4:43 PM
53. It started right up this morning. I changed the inline filter and drove about 1/2 mile and died. Cranks but won't turnover. I can see fuel in the filter. Tried starter fluid into the carb but didn't start.
scottss60 #1459199 07/18/2022 4:52 PM
New gas tank or old gas tank? If old it may have crud floating around in it. When the crud gets close to the fuel outlet the fuel pump sucks the crud up against the fuel outlet and shuts off flow. Let it set awhile and the suction releases and fuel flows again.
scottss60 #1459209 07/18/2022 6:11 PM
7
7 Offline
If it wouldn't fire on starting fluid you have an ignition problem, or lost the timing chain.
JW51 #1459226 07/18/2022 7:31 PM
54 engine, filter located after pump.
scottss60 #1459228 07/18/2022 7:42 PM
7
7 Offline
Oh,ok, no timing chain then. Turn the filter end for end, maybe it has a check valve built in and can't push gas through.
scottss60 #1459232 07/18/2022 8:07 PM
Curmudgeon
Curmudgeon
If it doesn't fire on starter fluid then look somewhere else.
I use a spark tester like:
https://www.amazon.com/Lisle-20610-Inline-Spark-Tester/dp/B0002STSC6
Martin Before I new any better had cut a steel tank line put on neoprene hose. One of those round spider nests got against that steel line and would act like a check valve. Now use a much better fuel,start,run,ride,drive,easy to trouble shoot,no vapor lock,no fuel pump,big filter !!!
