3 members (BC59, 54farmtruck, Hanks custodian), 79 guests, and 0 robots.
Topics128,157
Posts1,056,875
Members48,456
#145892 02/27/2006 9:24 PM
Apprentice
Apprentice
Went and got me a motor today! If I read my cheat sheet right,I know what I got.
Block number-00I8I59 F55M
This was on the bell housing too and stamped-This bellhousing must stay with this engine.Also got the 4speed tranny with it too!
So what do you bolters think," I really what your thoughts cause I want to be sure."
to start that's an engine code, not a block [casting] number - the first part should be all numbers, that is the I's are actually 1's, and it's a sequence number which all started at 1001, so yours is the 17,159th made - for the actual ID the F = Flint plant, the 55 = year, the M = 265 w/ HD clutch I believe if 55's were the same as 56/7 - is that what you think it is?
my thought is if it really is a 55 265, it doesn't have an oil filter or any provision for one, and the oil passage to the lifters goes thru the rear cam bearing, which can be problematic - good luck!
3B Offline
Hy 49dumper,although I do not have an American book I'm going to hazard a guess, I'll say you have a 265 V8 c/w a dual range 4 speed hydramatic.
X
X Offline
For '54 and '55 (1st & 2nd series), the M suffix was for the 235 with Hydramatic from a 3100 series truck. This one was from a '55.1.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
Apprentice
Apprentice
I came up with the same thing Xram53 did.Its aninline 235 out of a 55 3100 a guy I work with is turning into a lowride show truck.He is putting a V-8 in it.I didnt even know he had it.I went to his house to borrow some books and saw it sitting in the corner,so we did some tradin. smile
That adapter for trans needs to stay with that engine if you use it. Something about the alignment of the torque convertor I think. That's why they numbered both the same.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
How you gonna run a dump bed?
There was a PTO attachment for the Hydramatics.
1954 GMC De Luxe COE
Cool, I the 2 big trucks with hydramatics I've seen ran PTOs ran off the transfer case or brownie transmission.
There is a farmer near here with a GMC military truck with a hydramatic that has a hydraulic winch running of the transfercase PTO.
The GMC dump that I have been trying to buy with a 302 and hydramatic has a 2 speed auxiliary trans with PTO that the hydraulic dump runs off.
Apprentice
Apprentice
I am only using the 235 engine.Ive been reading up on the swap.Alot of good info from you bolters in here.The truck is already a stake bed dump,just a locked up 216 in it(surprise)LOL.I have been taking front end apart as I have time.It is in real good shape metalwise.I need all new brakes,lines,wheel cylinders,ect.ect.
Oh yeah,tires are bad too.Hopfully in a week my nieghbor and I will be able to get engines swapped this week and get it fired up to check out pto and hydraulics.I will keep you all posted as I progress.Keep posting ideas and tips for those of us that need all the help we can get.
