1 members (baldeagle),
89
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 16 Apprentice | | Apprentice Joined: Feb 2006 Posts: 16 | Well,the 49'er has a 6 cyl. but not origanal.Soooo,thought about small block V-8 or V-6.I willbe converting to 12 volt but what else (problems) can I expect.I know several of you have been here LOL.Also anyone tell me where I can get some manuals on my truck.Already called 800 number for specs.Thanks | | | | | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | Unless you have a good reason, I would just leave well enough alone. These trucks don't go fast or stop fast to begin with. The parts needed to make them do either limit their use a big trucks. Very few have the original engine left in them not that it matters, they aren't corvettes.
I can understand wanting more power to haul a load and am doing a diesel swap (originally intended a v8 swap), but that truck came to me without a drivetrain.
If it goes down the road and stops, a big truck is probably best left alone when it comes to swapping the engine. Otherwise you have a bunch of useless gearing behind that v8.
My 39 1.5 ton with a 55 235 and stock crash box can move my 8,600 lbs boat down the road without a problem and pull it to a reasonable stop from 55 mph (trailer is equipped with surge disc brakes).
just my $.02 | | | | | Joined: Feb 2006 Posts: 16 Apprentice | | Apprentice Joined: Feb 2006 Posts: 16 | Thanks 4.3in84toy I'm not sure what I will do yet.I plan to try and get the 6 running before I atempt anything.I have hilly land and if the 6 does the job I will keep it in.I dont drive fast anyway LOL.Thanks again | | | | | Joined: Jan 2006 Posts: 14 Junior Member | | Junior Member Joined: Jan 2006 Posts: 14 | I have a 48 Dump and I took the original motor out (it was still running but had a knock and babbitt bearings)and put in a 235 bored 40 over from a 61 and I think it works just fine. You might have to down shift on the bigger hills but your only able to run around 40 to 45 miles an hour with the original gearing.
naylor 36 Chevy 2 dr sedan 48 dumper 1 1/2 64 Chevelle 2 dr HT 51 F1 pick-up 52 F1 pick-up several stationary motors many old tractors
| | | | | Joined: Jan 2002 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2002 Posts: 59 | If your original engine is junk you might want to consider a 250. They are plentiful and cheap,parts are available at any parts store. The 250 is a strong engine with 7 main bearings They get a bum rap from a lot of folks,but are pretty tough motors, and do quite well in older bolts. It's a fair amount of work to swap one out but no where near the work to put in a v8. just my 2 cents worth..... | | |
