1 members (1 invisible), 100 guests, and 2 robots.
Topics128,265
Posts1,058,366
Members48,485
#145838 02/24/2006 7:22 PM
Apprentice
Apprentice
Well,the 49'er has a 6 cyl. but not origanal.Soooo,thought about small block V-8 or V-6.I willbe converting to 12 volt but what else (problems) can I expect.I know several of you have been here LOL.Also anyone tell me where I can get some manuals on my truck.Already called 800 number for specs.Thanks
Unless you have a good reason, I would just leave well enough alone. These trucks don't go fast or stop fast to begin with. The parts needed to make them do either limit their use a big trucks. Very few have the original engine left in them not that it matters, they aren't corvettes.
I can understand wanting more power to haul a load and am doing a diesel swap (originally intended a v8 swap), but that truck came to me without a drivetrain.
If it goes down the road and stops, a big truck is probably best left alone when it comes to swapping the engine. Otherwise you have a bunch of useless gearing behind that v8.
My 39 1.5 ton with a 55 235 and stock crash box can move my 8,600 lbs boat down the road without a problem and pull it to a reasonable stop from 55 mph (trailer is equipped with surge disc brakes).
just my $.02
#145840 02/24/2006 11:30 PM
Apprentice
Apprentice
Thanks 4.3in84toy
I'm not sure what I will do yet.I plan to try and get the 6 running before I atempt anything.I have hilly land and if the 6 does the job I will keep it in.I dont drive fast anyway LOL.Thanks again
Junior Member
Junior Member
I have a 48 Dump and I took the original motor out (it was still running but had a knock and babbitt bearings)and put in a 235 bored 40 over from a 61 and I think it works just fine. You might have to down shift on the bigger hills but your only able to run around 40 to 45 miles an hour with the original gearing.
naylor
36 Chevy 2 dr sedan
48 dumper 1 1/2
64 Chevelle 2 dr HT
51 F1 pick-up
52 F1 pick-up
several stationary motors
many old tractors
If your original engine is junk you might want to consider a 250. They are plentiful and cheap,parts are available at any parts store. The 250 is a strong engine with 7 main bearings They get a bum rap from a lot of folks,but are pretty tough motors, and do quite well in older bolts. It's a fair amount of work to swap one out but no where near the work to put in a v8. just my 2 cents worth.....
