Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (sron48, MickeyP, KingG, baldeagle, Gdads51), 39 guests, and 3 robots.
Topics128,007
Posts1,055,281
Members48,418
#1457615 07/06/2022 12:16 AM
On my '69 Chevy C10, 250, inline 6, there is a capacitor mounted on the firewall right next to the fusebox. It has no connector but a black wire coming directly out of it into a taped wire harness. The only exit from the harness of a black wire is to the oil sensor next to the dip stick. Without scraping insulation off and checking continuity, does anyone know what this capacitor is for? It does not show up on any of my wiring diagrams or wire layout pictures.
Tonerman #1457632 07/06/2022 3:55 AM
Are you sure it is a capacitor? A flasher unit looks a lot like a capacitor and that would be a reasonable place for it.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Tonerman #1457719 07/06/2022 8:56 PM
7
7 Offline
It sounds like someone added it for radio freq clean-up caused by the ignition system.
Fibonachu #1457720 07/06/2022 8:57 PM
No, it's definitely a capacitor. Same size and shape as in a distributor but without the contact/connection. Also flashers are bigger and have a different look. And mine (flasher and relays) are inside the cab on the fuse unit.
78buckshot #1457721 07/06/2022 8:59 PM
Doesn't look like an add-on, the wire is in factory wrap. But, that does make sense except for that it appears to be the only black wire going into the wrap and coming out on the oil sensor. Guess I will scrape the insulation off and see if I can find some continuity. Also...either the oil sensor is bad or my oil gauge is bad (autometer add-on) as it does not register. Electric, no tube.
