2 members (Guitplayer, MickeyP),
70
Mod | | | Forums66 Topics128,021 Posts1,055,356 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 37 Junior Member | | Junior Member Joined: Oct 2005 Posts: 37 | Does anyone out there know where I can get spring bolts for my 51 6400(the kind with the zerk on them)or does anyone have a junker that you can pull some from?
1951 6400 1954 6100 dump 2 1962 IHC scouts
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Go to a trailer manufacturer or a trailer repair shop. The one we have in town has all of that kind of stuff, usually on hand. They did for my 63 K20, Good luck, Scott | | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | What are you calling "spring bolts"? The single non-pivot one? the shackle ends? The kingpins? I got most of my parts from a spring shop that has been around for long time. Lots cheaper than mail order places. Otherwise, any vendor in this sites list might have them. The bigger trucks are a little harder to find parts for from vendors. I like Bow Tie Bits for bigger truck stuff. Try a good spring shop first.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: Oct 2005 Posts: 37 Junior Member | | Junior Member Joined: Oct 2005 Posts: 37 | it's the shackel side, both bolts are ruined. The shackels and bushing seem to be fine.
