3 members (KEVINSKI, dt235sd, Bill Hanlon), 109 guests, and 2 robots.
Topics128,049
Posts1,055,675
#1455421 06/17/2022 1:04 PM
Hello everyone, Can anyone tell me where I can get the washer kit to lower the pressure on my GM power steering pump? Thx, I appreciate your help. Olgzr
Curmudgeon
Curmudgeon
PS Flow Control Valve Kit by Bills Hot Rod Co available through Speedway. About $22
Fred
Ditto on Speedway motors. Assume you are going Chevy pump to Ford rack. On mine, even using max shims, PS still very light to the touch, but manageable
1940 Chevy KC 1/2-Ton
